Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
  1. #26
    Jul 2016
    South Carolina
    Default 1330 mainteance
    The 1330 engine is a variation of the motor that came out of a sea doo. Its been around for years and is very reliable. It will run for hundreds of thousands of miles! Just maintain it as required.
    Claimbo
    2016 RTS , GPS, entertainment cable. Outlets in trunk and trunk. White
  2. #27
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    Quote Originally Posted by Claimbo View Post
    Claimbo
    did not know that.
    Can you tell us what model Seadoo it came from?
    2017 F3, SM6-basic black, plain and simple
  3. #28
    I see that this older thread (from 10/2013) has been resurrected. Interesting to see the comments.
    I bought mine in April 2014. That's when we get the "new" ones here.
    Turns out the 1330 was as advertised. I have 28,000 miles on mine now and other than headlight burnouts, there have been no mechanical issues.
    The 1330 is now the "fleet" engine of choice for BRP.
    Jul 2017
    sarasota, fl
    still wondering which Seadoo has the 1330 engine
  5. #30
    Aug 2012
    Central Coast, CA
    I don't know about Seadoo, but IIRC at the time it was acknowledged the ACE family of motors was from their quad division.
    2020 RTL SE6
  6. #31
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by KX5062 View Post
    https://www.rotax.com/en/products/ro...-1330-ace.html
    Here is a link to all of the Rotax engines and what their application is.
    The only application for the 1330 listed is the Spyder.
    2020 RT Limited , Petrol Blue
  7. #32
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default I do 5K oil/filter changes
    I may be overly protective, but after break-in I do 5K oil and filter changes, and I do them myself. Doing an oil/filter change is an easy job, just take your time, follow the steps, and have a low profile oil pan to catch the oil. If you have a low profile pan you don't have to jack up the bike. Living in AZ I'm concerned about the heat and potential impact.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
