Results 1 to 25 of 32
    Registered Users TmanOK's Avatar
    Oct 2013
    Edmond, OK
    Default 2014 Rotax 1330 Ace Engine
    I just watched a Can-Am video on this new engine.
    Here are there recommendations for service.
    Break in - 3,000 miles
    Oil Change - 9,300 miles
    Coolant & Spark Plugs - 28,000 miles
    Transmission Filter - 28,000 miles
    Valve Adjustment - Never
    Sine the 2014 will be my first purchase, I would appreciate experienced owners comments.
    Thanks.
    Sent from my iPad using Tapatalk - now Free
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Mileage is just one factor, you must also consider time. Some riders may take 5 years to get to 28,000 miles while others are there in a season. Initially, stick with the manufacturers recommendations, that way your warranty will not be jeopardized.
    George
    2017 BMW R1200R
    It appears to me that BRP has taken a swing at addressing owners' complaints about the cost of servicing these bikes!
    Oct 2013
    Edmond, OK
    It interests me because the dealer I am considering is an hour and a half away.
    You travel as far as you need for the best service for these bikes...
    Oct 2013
    Edmond, OK
    Yes. There is one dealer here. But I don't feel food about them.
    Invalid Emails
    Apr 2012
    Canal Winchester, OH
    Quote Originally Posted by TmanOK View Post
    Since the 2014 will be my first purchase, I would appreciate experienced owners comments.
    Comments about what? No one has any experience with the 2014 models. How can anyone comment? Consumer Reports doesn't rate new models or major redesigns because there's no practical experience to base anything on. Six months after the 2014 models have been out there, that is when you should be looking for comments.
    It's a crapshoot to be the first in line for the new Spyders, The 2013 models strayed from the previous design and look what happened there!
    Default Gotta say..!!
    great..!! Only comment. If it all works out as planned. Time will tell..!!
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2013
    Edmond, OK
    I was referring to the suggested maintenance schedules.
    I have never seen spans like that.
    washington state
    maintenance
    2012 Spyder RT SE5 Brake pedal mod
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    If the 2014 is as easy to service as my 2011, I will change the oil and filters (oil & Tranny )every 5-6,000 miles just for piece of mind. I think 9,200 miles is a lot to ask of your oil .
    Happy Owner
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by fastfraser View Post
    I agree. While most cars today go that long and my '13 accord calls for filters every other oil change, I wouldn't feel comfortable with such long usage on a bike. Curious to see where the transmission filter is located and what type it will be.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    I'm looking for the shop manuals to become available online...
    Very Active Member MidLifeCrisis's Avatar
    Apr 2012
    Gilbert, Arizona
    I'll wait for the * in the service interval. There's almost always something associated with a * or ** or *** that says you're well within the exception or extreme conditions. At least, it matters here in AZ. Both of my cars have the above designations with regards to extreme conditions...heat - check, dust - check...in for service we go.
    Jun 2013
    queens ny
    Default 1330 engine
    someone told me that this new motor has been around a few years and used in some other snow mobiles is this right
    NO BIKE AT THIS TIME
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    If you take a look at the owners manual. It states miles or 1 year. Which ever is first.
    Invalid Emails murphybrown's Avatar
    May 2010
    Chelan, WA .. the dry side!!
    Default Just the time needed to
    ...Get warmed up...1 1/2 hr is a hop, skip and jump...you are blessed to have a dealer that close and you will be twice blessed if he is knowledgeable on all things ..In case he isn't then just ryde until you find the CHOSEN ONE...... are so worth the effort... on doing your research for your adventure into hood....
    My Motto Is:
    Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
    Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
    White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
    Ms Spydee: 2010 RT SE5
    Registered Users spydercatjohn's Avatar
    May 2013
    The Villages Florida
    Oil change will probably be 9300 miles or 1 year whichever comes first. Since most people will ride less than 4500 miles annually (the current oil change mileage) the cost of an oil change will remain the same, about $300 per year. But there will be savings from no valve adjustment, about $600 which is good.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by cuznjohn View Post
    No, this engine was developed for the Spyder. The confusion may come from that the design was based on what BRP calls ACE (Advanced Combustion Technology). Same technology used in a different engine. Snowmobiles don't use gearbox transmissions built into their engines.
    Oct 2013
    Edmond, OK
    Thank you wiredux. I have saved those.
    Oct 2013
    Edmond, OK
    Thank you murphybrown. I try to do research so I can make an informed decision.
    Thank you to all you wonderful Spyder riders for your help!!
    It is based upon those four-stroke triples...
    but it's been in the works and getting street-testing for the past three years...
    Thanks for those pics of the maintenance information!
    RE: Service Intervals: Longer than on previous models--hence the comments about less maintainece costs.
    RE: Experience out there: Other than prototype information, many are still waiting to pick up and start driving their machines--once the dealer's get them. It's going to take three to four months till we have some good information covering a few thousand miles of actual operation.
    Invalid Emails
    Ormond Beach FL
    Cool
    Check with your local
    Better Business Bureau is one good source and the Credit Department at some of your local banks.
