Page 1 of 2 12 LastLast
Results 1 to 25 of 48
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Default Can we talk about tire pressure
    Just a reminder that with the temps falling it is a good time to check your tire pressure. When for an hour ride today and still had some instability over 65mph When I got home and let things cool down I checked my pressures. I have not checked them in 1 month but here is what I found Frt 14psi rear 24.5psi. A month ago they were Frt 18 rear 28. Could that be a factor in my squirrelly 65+ situation? Cooler temps always cause pressures to drop. Now the discussion. I have been driving Corvettes for over 10yrs in fact traded my '98 for the Spyder and found that using nitrogen instead of air had some benefit to it.
    1. Air(oxygen) can and does weep through rubber.
    2. Nitrogen does not
    I know a lot of people say nitrogen is snake oil but my experience tells me differently. With air after a long drive my tire pressures were usually 4-5lbs higher when they were hot. With Nitrogen it was usually 2-3 lbs. With air every fall I had to add air because the TPMS would start yelling at me. I ran year round with nitrogen and cold tire pressure remained the same. Nitrogen molecules are larger that some of the gasses(oxygen) in air that weep through rubber. That is the scientific reason it does not weep as much. We all know racers use nitrogen because it simply is more stable and predictable for hot tires. Since we have 2 ply crappy tires I would assume they may weep even more. Yes I know air is 79% nitrogen but that 21% can and does shrink more with lower temps than pure Nitrogen does. I am considering going to full nitrogen on my Spyder and wonder if anyone else has and what results were?
    Thanks for your thoughtful replies
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Mar 2008
    Allegan, MI
    No comment on the nitrogen, but if you checked your tires after a ride, even after a cool-down, you may wish to check them again in the morning. Tires should be checked cold, and it takes them a long time to reach ambient temperatures...especially tires as big as those the Spyder uses. JMHO
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Jun 2013
    NE South Carolina
    Quote Originally Posted by NancysToy View Post
    No I checked them cold 10hrs after the ride and they were set at the previous pressures cold but the ambient was 10-15deg higher at the time. I actually set them .5lbs higher than my 18/28 because I know the temps will be dropping in the next week or two.
    Registered Users Jlbrandt's Avatar
    Sep 2013
    Yankton,SD
    Dealer told me to use nitrogen in rear tire. He says they are seeing better tire wear.
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    i use nitrogen in our cars and I can attest that my pressures stay constant. i've always gotten great tire wear since switching over years ago. when I finally get a spyder it will have nitrogen it all it's tires.
    Call me cheap ; but I think that a lot of the hoopla concerning the use ot nitrogen in tires is just an excuse to sell you something...
    I use the cheap nitrogen that's got a little bit of air left in it ...and I check my pressures before hitting the road!
    Invalid Emails
    Mar 2012
    NW Ohio
    I, also think you are making a big deal over nothing. Air up those crappy tires to the pressure you like and go out and ride. If not, go out and install some non crappy tires and inflate with whatever you see fit. my2$
    Jun 2013
    NE South Carolina
    Quote Originally Posted by DJFaninTN View Post
    Ya know thinking about how quickly the rear tire wears(and usually the center) I wonder how much of that is due to the 4-5 extra lbs that air causes when hot hmmm....
    western Colorado
    Quote Originally Posted by Magdave View Post
    I use it in my 11 Subaru & noticed a 2 MPG increase. Just not sure I want to spend $20 for 3 tires on spyder
    Jun 2013
    NE South Carolina
    Quote Originally Posted by happyspyder2039 View Post
    Yep that is the question. BRP should be doing it during setup IMHO.
    Very Active Member flaggerphil's Avatar
    Mar 2012
    Florida Space Coast
    My dealer put nitrogen in my tires. I our race series most of the teams use nitrogen instead of "air."
    That being said, every vehicle I've ever owned has had to have the tire pressure adjusted a bit over time.
    Phil
    I may be old, but I got to see all the cool bands.
    2011 Spyder RT-AC
    Registered Users flybuddy's Avatar
    May 2012
    Fort Myers
    Consumer reports did a study on this years back and found a 2.2 avg pressure loss in Nitro tires vs 3.5 for air (they didn't specify duration but the study lasted a year on 62 tires).
    Also the nitrogen is not 100%, 93% is considered "pure" in the industry. That's only a 15% diff. Another issue is for those of us that check air monthly, how to you top off with nitro conveniently.
    2012 Spyder RT
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Default TPMS
    I have a TPMS on my Spyder. I love it!!!
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Very Active Member Flanker's Avatar
    Apr 2013
    Michigan
    My thoughts, exactly.
    2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
    May 2013
    SW MO
    Nitrogen for non-racing vehicles is nothing more than snake oil for tires.
    Silver Shadow
    2013 RT-S Lamonster Edition (vented windshield,
    NBV highway pegs, Two Brothers exhaust)
    Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
    A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to “The United States of America,” for an amount of “up to and including my life.”
    western Colorado
    Quote Originally Posted by OldCowboy View Post
    Personal preferance- like oil,Gas, laundry detergent, Dog/Cat food, hotdogs, steaks I could go on. What works for some may not for other so
    Invalid Emails
    Ormond Beach FL
    Dave
    i have both to deal with and really don't see any advantage to nitrogen. The SRX that my wife owns has nitrogen, my Silverado has compressed Air and so does the Spyder. The Spyder requires more attention then the other two" I guess it is the OEM Kenda Tires?
    Bryant, Arkansas
    "2 ply crappy tires", just curious if you did any research on your Spyder before you bought it, seems that you are unhappy with everything related to Spyders. Just a observation from this end.
    Cruzr Joe, a Happy Spyder Owner
    Invalid Emails
    Ormond Beach FL
    Cool
    Quote Originally Posted by flaggerphil View Post
    racers also use nitrogen for another reason.... It is portable, cheap and high pressure for air tools and the adjusting of tire pressures for track conditions
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    I'll dive in here. The biggest reason for nitrogen use in tires is deterioration. Water in air reacts with rubber compounds and corrodes metal rims and any exposed cord steel inside the tire. Water is present in compressed air, that's why there are drains on compressors. Some shops don't do a good job of keeping water out of the compressed air. That water is carried right through the lines and hose direct to the tire. Once in there, it stays. One of the best things to do before filling/topping off a tire is to press the valve stem on the air chuck, if mist comes out, there's water in the line. I can tell you from fact, I have taken tires off rims and have had as much as a pint of water come out of the tire. Sometimes more. Too, there is a procedure to follow if putting nitrogen in tires that have previously been filled with air. The tires must go through a nitrogen/air purge. This is normally done three times before the final fill with nitrogen. Newly mounted tires are not subject to this procedure, unless air is used for the preliminary mounting. Another consideration. The tire dealer should have a system that generates 100% nitrogen. This system is expensive hence the high cost of nitrogen fills.
    Bottom line, if you're going to replace the air with nitrogen, it has to be done properly with the purge procedure. If not, you're wasting you're money.
    I have nitrogen in my truck tires. It was put in when I had the new tires mounted. I haven't noticed much change ant change in fuel mileage. I have noticed a better ride. I have had them topped off twice in two years. The tire dealer does not charge for top off. They also have the 100% nitrogen system. Would I put it in our Spyders. no. Because It's not worth the cost to do it properly.
    JMHO.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Jun 2013
    NE South Carolina
    So you are going to defend Kenda tires now ? No I did not research the tires on it I though $24k would get me some decent ones though.... I paid less for my Terrain. Right now I am frustrated because the myriad of issue mine is having so glad yours is so good have fun riding.
    Jun 2013
    NE South Carolina
    Quote Originally Posted by bruiser View Post
    JMHO.
    Exactly my experience with my Vettes and I forgot to mention the water part it caused my chromed rims to bubble on the beads causing leaks which is why I went nitro to begin with thanks for sharing good info
    Other than the fact that they're only a two-ply tire; what's wrong with the oem Kendas??
    Are they sneaking out at night to steal from other houses in your neighborhood?
    Are they adicted to painkillers?
    Are they cheating on their income taxes?
    You've been rather non-specifc; what's up??
    Mine just leave rice on the garage floor.
    USAF '69-'89 E7
