Fuze block installed
Finally I installed my Fuze block, took me about two hours cause I was grilling at the same time. I used the switched accessory wire upfront for my switch/keyed connection and ran the positive and ground to the battery......easy install.
If you ryde like there's no tomorrow, there won't be any
Accidents hurt - safety doesn't
Any pictures?
2012 RT-S SE5 with Web Boards, custom graphics and battery tender leads
Originally Posted by Barlock
Any pictures?
I knew better to post this without pictures. I will post some tomorrow.
Super easy install. I put one in the frunk and am about to add another under the seat to power stuff in the rear.
Central Arkansas
2010 RS-S SE5 Pearl White
So..................you were grilling your fuze block, or you installed it on your grill? You Sir, are the multi tasking master!
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
