Results 1 to 19 of 19
    Alberta, Canada
    Question Winter battery maintenance
    What do people do with their Spyder batteries during winter months? My Spyder will be stored in a non-heated garage. On my previous bike I used to just remove my battery and bring it home, but then it was very easy to do on that bike. With my new Spyder it sounds like quite a hassle. Maybe I should just connect a trickle charger to it and leave it in the bike? Any suggestions?
    Mar 2009
    USA
    Mine is stored in an unheated garage as well. I just hook up a Battery Tender through the 12V outlet in the trunk. Works great and the battery is ready to go as soon as the spring riding season starts.
    Alberta, Canada
    Default Thank you
    Quote Originally Posted by hottrodd7 View Post
    Thank you, Hottrodd7, I'll do the same.
    May 2013
    SW MO
    Quote Originally Posted by Barlock View Post
    Make sure you move the #6 fuse in the right hand fuse box to the #7 position. See page 60 of your owners manual.
    And, BTW, and on your new .
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by OldCowboy View Post
    That's only if he has a 2013. He did not share that info with us.
    The trickle charger suggestion is the way to go.
    Alberta, Canada
    Default Thank you
    Thank you, gentlemen. I really appreciate your help and a kind welcome to the community. BTW my Spyder is 2012 RT-S SE5. Are you saying I do not have to move that fuse then?
    Motorbike Professor
    Mar 2008
    Allegan, MI
    You can charge the 2010-2012 Spyder RT directly through the 12V outlet without changing a thing. There is no alternate slot on that model anyway. You can also charge through the jump start terminals under the seat, or via a fused pigtail (included with most chargers) connected directly to the battery. Do not use a large automotive charger or a standard "trickle charger". It is best to use a battery maintainer meant for motorcycle (small battery) use, like a Battery Tender, Accumate, Optimate, or Xtreme. Any motorcycle shop should have an appropriate charger/maintainer.
    Active Member Raknid's Avatar
    Central NJ
    We ran a pigtail under the seat and keep the BatteryTender hooked up if sitting more than a couple weeks.
    Default There you go...!!
    both methods work. But if you don't want to remove the battery the battery tender is the way to go. To pig tail you would have to get to the battery to hook it up. So going through the power outlet (cigarette lighter) or alligator clips to the posts under the seat will save the work of going to the battery.....
    May 2013
    Hollister,Ca.
    As far as I know,the Deltran Battery Tenders do not come with a charging plug for the 12 V outlet.
    Can you buy the adaptor that has the same pigtails for the Tender?
    Question: How cold, does "cold" have to get before it becomes a problem?
    At what point does freezing become a possibility?
    Alberta, Canada
    Default Cold
    -40 is not an unusual thing here in Alberta
    May 2013
    SW MO
    Quote Originally Posted by Spyder4Tess View Post
    While the Deltran Battery Tenders do not come with a cigarette lighter plug, they do sell one as a separate accessory.
    May 2013
    SW MO
    If that temp doesn't freeze car batteries, it shouldn't freeze a fully charged motorcycle battery. As near as I have been able to determine, a fully charged battery will not freeze unless the temp gets down to -77F or -67C (http://www.batteryfaq.org/)
    Thanks for that info. I knew that a battery is good for well below-zero; I just wasn't sure HOW well...
    Jun 2012
    Fairmont, Minnesota
    If you use the pig tails, review many older posts to find out how to hook up the negative lead. Do not remove the connection you can see under the seat.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Adapters available from Deltran, Powerlet, and many other places. Specifically you are looking for an SAE-to-cigarette adapter.
    May 2013
    Hollister,Ca.
    Thanks for the info.
Tags for this Thread
