I know the panel w the scoop is new, which other panel is replaced? The ones w the black vents next to the frunk, or the upper panel by the mirrors?
Also, what are the black plug looking things on the upper panels?
The panel that surrounds the foglight is new. Same opening for the black foglight panel but the new panel is extended so that it goes underneath the other new panel. Look at the pictures and you can see what I'm talking about.
The black plugs on either side are my auxiliary power outlets. One side is a dual USB port and the other side is a conventional cigarette lighter outlet. Both items are by Blue Sea and I picked them up on Amazon.
The panel that surrounds the headlight is new. Same opening for the black headlight panel but the new panel is extended so that it goes underneath the other new panel. Look at the pictures and you can see what I'm talking about.
I think I know which panel you mean now, but that is a fog light not a headlight.
Duh!!! My bad!!! It is the foglights and not the headlights. For some reason I was thinking lights and not really paying attention to what I was posting. I guess it's my age and that CRS kicking in on me.
BRP should seriously consider doing a run, even a limited one, of the new panels in previous colors. At least in the 2013 colors if it helps people with heat problems.
It would be a nice option when you order, they wouldn't have to produce but a few and mention it takes extra time for special colors. That way they don't lose over producing them.
This all of course depends on their manufacturing process, I know its a major ordeal in car manufacturing to add special colors to an existing process line.
Just a thought/suggestion. Perhaps you could consider doing a two-tone RS-S and mixing in the new panels in a different color.
Carl
I was thinking about doing the black on my white pearl. I've looked at your pics, maybe I'll photoshop one, recolor the panels black and see how it looks. Can't wait to see how it helps to dissipate the heat in the engine compartment, cool it down. With lots of time, around $200 and some patience I reduced the heat ON the left side panels by 50% but I'm just not comfortable with all that heat in there, I'm afraid it's going to start effecting the engine components.
I know the telephone people don't really know what's going on but the one I talked to about the panels last week put me on hold to do some checking, came back and told me that a fix is under development and that I should call back in a month or so to see if it's available yet. She did not know what, when or oh much. I'm hoping for a fix but not expecting one.
Carl
I was thinking about it. It would look good with black panels since some of the parts are black already,
However; it should be black in satin to match the finish on other panels.
And here we go, back to square one.
