Chain?
In Pitbulls' video on naked 2014 was that a chain rather than a belt?
2015 RTSE, Red Pearl, Shorty Antenna, Chrome Rear Rack, Deer Whistles, BajaRon Anti-sway Bar
SpyderLovers Founder
Nope, it's a belt. It's a new material than ours.
chain
no it is still belt driven but the say it is a heavier type belt
NO BIKE AT THIS TIME
yes, heavier belt to handle the torque
Hopefully the belt will not cause flapping like prior years.
2012 Spyder RT SE5 Brake pedal mod
Hoping it doesn't make the noise that my 2012 RT does.... I lube it every 400 miles.....
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Since I started wearing good ear plugs, my Spyder makes no noise at all!
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
Belt
What do you mean you "lube it every 400 miles"?
BRP has a TSB out on "lubing the belt"
That sounds kind of catchy!
A small dab of grease on your fingertip, and wipe a bit onto the belts inner cogs at several points around it...
It outs a bit of lube on the pulleys in order to keep the squeaking to a minimum as the belt works it's way on and off of them...
