Results 1 to 24 of 24
    Aug 2013
    Default Bigger Brake Pedal
    I've searched around a bit, but can't find something specific?
    Has anyone found a bigger/larger brake pedal pad for a ST ?
    Perhaps I need to call some of the sites that sell the pads, because they just don't seem to list ST in their product lines yet?
    I find that the factory brake pad is sorta small to hit, hoping to find something 2-3 times larger that bolts on?
    Jun 2012
    Cumberland Cove - Monterey, TN
    I thought Reggie at TricLED had something that might work. You could also do up something yourself as it wouldn't take too much work or engineering to make a new pad.
    Carl
    Bryant, Arkansas
    Reggie at Tricled has an oversized pedal that works great.
    Cruzr joe
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Brake Pad
    I haven't done it yet but I'm going to take the pad that we to when in installed the Seal boards, weld a short piece of scrap metal (as long as its flat) to the break peddle then cut you may have to cut off a little of the rubber, and there you have it, an extended break peddle cut off length to suit you. Then I took the foot peg rubber and after drilling holes to match you have it. Just don't make it too long.
    washington state
    I did my own brake pedal mod by replacing it with a car rubber pedal I bought from orielly auto part store. I can send you a picture if you want.
    Invalid Emails
    May 2013
    Jacksonville TX
    Default Break Peddle
    I just wrote a thread that I think will work if you have install floorboards
    Aug 2013
    Quote Originally Posted by SPYDERFUZZ View Post
    I have a ST-S SM5, it comes w floorboards.
    Aug 2013
    Quote Originally Posted by jerpinoy View Post
    Please do.
    I was hoping for a simple bolt on, but not sure if the pad is even separate from the rod/lever?
    Aug 2013
    Cruzr joe
    I only see RT and RS listings.
    Jan 2013
    greenville, sc
    I MADE MINE 1" HIGHER I USED A SCRAP PIECE OF ALUMINUM CHANEL DRILLED 2 HOLES BOUGHT 2 1 1/4" STAINLESS BOLTS USED ORIGINAL BRAKE PADVisitedStatesMap.jpeg
    Aug 2013
    I don't really need it higher I believe I would just like more surface area so it's easier to hit....especially in an emergency.
    Jul 2013
    Afton, TN
    Default Brake pedal Mod
    I used a piece of aluinum & made it about 1.25" wider. I them mounted the oroginal pedal pad on top of the fabricated piece. I have no trouble finding it now.
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Polish Eagle View Post
    I see a possible problem with your setup. For many reasons the brake pedal could have some extra travel. For that reason, BRP has setup the floorboards with a release mechanism so the the front of the right floorboard will fall away so you still have full pedal travel. If the pedal pad hits the floorboard before the pedal arm hits the release trigger it could be dangerous. I think it is something to check out.
    Jul 2013
    Afton, TN
    Thanks for the heads-up & info on the floor board release. I didn't know about that. I had given some thought to the pedal hitting the floorboard, for 1 of many reasons, but figured if I lost that much travel quickly, I'd be in deep doo - doo anyway.
    Default The pedal from TricLEDs
    Aug 2013
    Ill take it, does it bolt on? Lol
    Yup! Right back as a direct replacement for that little "steel wool" pad!
    Aug 2013
    Is that the one from Tricled?
    Again, it only says for RT and RS
    Aug 2013
    I should start a movement for ST products.
    Oct 2007
    Default Bigger brake pedal
    Quote Originally Posted by quickster47 View Post
    Carl
    How do I get ahold of Reggie at Tricled...??????
    Oct 2007
    How do I get ahold of Reggie at Tricled. I would like to order this larger brake....
    ...in the pink (Girls On Spyders)
    May 2010
    Friendswood, Texas
    resize floorboard.jpgThis is from ISCI
    Linden, CA
    Default YES here is the way to go..
    Here is what I did, I hated my brake pedal it was way to small and I feel very unsafe, I am suprised
    that the govt. allowed it on the Spyder, one of the vendor/sponsors here ISCI is the manufacturer.
    The photos here is of me installing it on my GS/RS but I bet the unit here will work on yours and if not
    they will have one that will. the new brake pedal is about 4 in. forward from stock and it is double the
    stock one in size. Very high quality materials were used to make it and well worth the price.
    I give it a Dave's 5 big thumbs up
    Aug 2013
    that the govt. allowed it on the Spyder, one of the vendor/sponsors here ISCI is the manufacturer.....
    This is a very good question.
    This is why I asked for a bigger pedal.
    I owned the bike 2 weeks and went to move it, it started rolling on my slight incline driveway. I went for the brake a couple times and couldn't seem to hit it in a panic.
    Lucky my truck caught it
    I learned early that in a panic/ emergency that I need a little bigger brake pad.
    Thank you for the post, I guess in the worse case I will need to fabricate a little.
