Results 1 to 14 of 14
    Aug 2013
    Northern California
    Default The Non-missing Grill is Missing
    Had the in for 1000 mile service and looks like they forgot to attach the grill on the left side by the drivers foot, as it flew off down the road. Have to order a new one. My question is, as I am leaving on a long trip for 5 days, will this cause any issues Wit the ?
    thanks
    Very Active Member SNOOPY's Avatar
    Aug 2013
    You'll have more air flow and less heat. LOL
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Suggest, ever so nicely to your dealer, that since they caused the problem, they need to make it right in time for your trip. Ask if there is a problem, riding without it. If they say not to do so, tell them to either give you a loaner Spyder, or they can pull a panel off another bike for you to use for your trip. Their fault . . . their responsibility to make it right.
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Default Relax a bit..!!
    not a problem ryding without it. Do check with the dealer, seems they may not have re-installed it properly. Read a lot about panels falling off and some threads on how to secure them better..good luck..!!
    ​2012 RS sm5
    Quote Originally Posted by Hayfield View Post
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    For sure they didn't install it correctly. It's on them if you can convince them of it. Since that panel is mainly to the oil tank, I don't see a problem with running without it other than that gaping hole.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Jun 2010
    Las Vegas
    It will make checking the oil much easier on your trip! When you get the new panel put a piece of velcro on the panel and one on the frame and it won't come off unless you want it to. Do that for the right side panel also. Dealers have a knack for not attaching the panels properly.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    The last two times I had my serviced, I found loose and improperly installed panels. I always do a walk-around to make sure they did not damage the while in their care. It's a bummer when a panel blows off while driving down the road--the vehicle behind seems to nail it, or it flys off to netherland--never to be found again.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Quote Originally Posted by SpyderAnn01 View Post
    Thanks Before my 600mi service you had to pry mine off with a screwdriver ( JK) but the tech in his infinite wisdom lubed them. Had the rear pop out, glad my wife saw it, is how I found out what he did. I just got done cleaning the grommets with rubbing alcohol and moved the rubber to the top and replaced it with a piece of industrial grade Velcro. Nice and tight now.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    washington state
    Welcome to the party, I lost my rt hand side and after few phone calls and nice conversation with BRP with reference of my dealer to talk to them. Now BRP gave me credits to purchase my lost panel. I'm still waiting for my new panel being ordered by my dealer.
    2012 Spyder RT SE5 Brake pedal mod
    May 2013
    Stanton, ca
    OMG not the screen on the left side!
    I would not ride it. It will throw codes and eventually put you in limp mode!
    Get it fixed now!
    I am kidding obviously
    But... if your left shoe melts don't say I did not warn you! You might limp home on a melted shoe!
    Again I am kidding!
    Bob
    2011 RT-S SM5 - Black
    Aug 2013
    Northern California
    Default Good news
    We got ready to go on our trip yesterday and it just happened that the dealer was on the way. We rode into the service department, asked the manager to take a look, and he went back int the shop and produced the missing part, installed it and we were on the road. Took 15 minutes. Thanks to Forrest at Elk Grove Power Sports.
    Registered Users SpydherLuv's Avatar
    Mar 2011
    Fair Oaks, CA
    EGPS is a great dealership! Glad to hear they took care of you.
    Have a safe trip.
    Jun 2013
    NE South Carolina
    I did see a mod at the dealer a guy did to his. He attached a bracket to it and put a short piece of light gauge wire rope from his frame to a small carabiner that attached to the bracket it was the ultimate solution IMHO.
