Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default what's up with my gas cap ?
    the last few times i've put gas in, the cap is LOOSE. all by itself. this is the new style large cap that bob d. was nice enough to send me cause brp never did, and still hasn't. i do make sure it is tight after i get gas. this has just started happening recently. anybody else having this problem? i don't want to experience a spyderanne situation.
    it was fun while it lasted.
    Registered Users JJW SpyderRider's Avatar
    Jun 2010
    Rockton, IL
    Quote Originally Posted by coz View Post
    You need to watch Lamont's video on how to install the gas cap correctly?
    RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
    Member of the WSR (Woodstock Spyder Riders)
    Are you tightening it a couple clicks, or just till it feels tight?
    Active Member 2 Cruysyn's Avatar
    Nov 2011
    Broken Arrow, OK
    You're not alone. This is the response my service department received from BRP:
    I have talked to BRP about this and they said that temperature change might affect the torque required to reach the click. As long as you are not noticing any fuel residue at the cap area this should be normal.
    Temperature change? Ya think! Not quite sure what to make of their answer so I check the cap every now and then particularly when I get back from a ride. I raise the seat to let the "temperature change" out anyway.
    Baja Ron - Dimple - Ultimate - Lamonster Garage - K&N - Smoothspyder - Amsoil - Hiflo - FOBO - Spyderpops
    Sena - Dynaplug - Shoei - Tourmaster - Garmin
    Default Depends..!
    Are we talking rattling last thread loose or just easy to remove loose..?? Hard to imagine the cap coming loose on its own. Only thing would be heat pressurizing the tank causing the clicking feature to activate prematurely...upon cooling the cap is loose..good theory but will it hold water..??
    ​2012 RS sm5
    May 2011
    cincinnati, ohio
    Default pretty loose
    one time soon after i got it, i didn't want to open, would just spin. could be a defective cap, i'll put my old one back on, never had a problem with it.
    Active Member DLewis's Avatar
    Greenwood, SC
    Mine is just the opposite. The last few times I've re-filled, it just spins and spins, clicking all the while. Finally after a few tries, it comes loose. Go figure. (and no, I'm and NOT trying to tighten it, for those who think that I am) I watched the video (twice) so I am well informed.
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Quote Originally Posted by JJW SpyderRider View Post
    That's the video right after the "How to Insert Key" video isn't it?
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Coz...
    I sure didn't mean to send you a handful of trouble...
    If it was me and my bike; I'd stop in to the dealer and ask them to replace it.
    Mar 2012
    NJ
    User Error.....
    washington state
    2012 Spyder RT SE5 Brake pedal mod
    May 2011
    cincinnati, ohio
    Default maybe
    i'm not smarter than my gas cap.
    Cheshire in UK
    Default same here
    Had to re-tighten the gas cap 4 times today at one point it was so loose that when i touched it with my finger it spun open. I thought this was one of the reasons for changing the cap in the first place...its not really reasonable to expect people to keep stopping to check their gas cap is still tight due to temperature changes...and if gas caps are so prone to this, how come my cars gas cap never does it no matter how hot it is and i don't want to hear how the spyder is different than a caris it really so hard to for BRP to find a gas cap that works? if they are supposed to be "ok" if they are "slightly loose" then why the hell all the fuss about tightening them in the first place...BECAUSE THERE SUPPOSED TO STAY TIGHT....i'm just saying...that's all .....ok i feel better for that
    May 2011
    cincinnati, ohio
    Coz...
    Bob , i'm glad that you care about me more than brp does. thank you canam girls for backing me up on this. i really AM smarter than my DEFECTIVE gas cap. i'm probably smarter than my DEFECTIVE, LEAKING MASTER CYLINDER CAPS too.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    It is the new "Child Proof " cap.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Quote Originally Posted by Magdave View Post
    Child-proof??? That's it! I've been beaten!
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Default me too
    My hubby has been accusing me of not tightening the gas cap because every time he goes to fill up, it's loose. I just called the dealership and they want to see it when it's loose. I topped off on my way home on Sunday, but who knows if it's loose now. I'm sure not going to check it and see if it's loose and then leave it that way.... I figure I'll just get on and ride down there and hope it's loose when I get there
    2015 F3 , Pearl White
    Bryant, Arkansas
    Bob sends those broke gas caps out to everyone ................... No one told you
    Jun 2013
    NE South Carolina
    The truth about "clickable" gas cap is you are supposed to only get 3 clicks when you tighten it. If you spin click it you WILL ruin it. This may or may not apply to some of the people having issues. In the old days it did not matter how many clicks it does now since those too started to fail the OEMs came up with the 2 click recommendation.
    Q: Do I need to turn the gas cap so hard that it clicks repeatedly.
    A: Different gas caps require different procedures. However, many vehicles today require the gas cap to click at least three times. If the gas cap is not installed properly, the “check engine light” can go on. An improperly tightened gas cap could allow excess fuel vapors to evaporate and enter the atmosphere. Gasoline vapors contribute to smog. The best advice I can give is to check your owner’s manual or to see if the gas cap itself has any writing on the top of it that identifies the procedure.
    Registered Users SpydherLuv's Avatar
    Mar 2011
    Fair Oaks, CA
    Awhile back my technician recommended pressing down (light pressure) on the gas cap while tightening which I've always done and so far I haven't experienced a loose cap.
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Default To remove and install a gas cap.
    Gas caps are righty tighty and lefty loosey . That's IMHO.
    MIKE
    Jun 2012
    Longmont, CO
    Default got a "new new" gas cap
    Quote Originally Posted by vondalyn View Post
    So I rode down to the dealership the other day and of course it was NOT loose when I got there, but they replaced it for me anyway. They put it under an "emissions warranty" in case anyone who has the same issue wants to mention that to their own dealership.
    May 2011
    cincinnati, ohio
    Default hey von
    there is nothing wrong with our gascaps . most of the others said so. that makes us wrong, right? i hope no ones spyder burns down because of it.
    Jun 2013
    NE South Carolina
    To me the problem is obvious and BRP needs to fix it. These caps were not designed to be heated to the point of not being able to touch them. Plastic warps, seals deteriorate under extreme heat and increased pressure. Most of us do not live in the great white north. Some of us live where it never snows. C'mon BRP this is not rocket science a little common sense goes a long way. They need to insulate the smaller than everyone else's gas tank.
    Jun 2013
    NE South Carolina
    To me the problem is obvious and BRP needs to fix it. These caps were not designed to be heated to the point of not being able to touch them. Plastic warps, seals deteriorate under extreme heat and increased pressure. C'mon BRP this is not rocket science a little common sense goes a long way. They need to insulate the smaller than everyone else's gas tank.
