Results 1 to 22 of 22
    Registered Users figmotoday's Avatar
    Nov 2012
    Midwest United States
    Default BajaRon Sway Bar Video
    Does anyone have a video of riding/demonstrating a spyder with BajaRon Sway Bar? I'm looking at pros/cons of replacing stock sway bar with BajaRon Sway Bar. Possibly, I need to find a spyder with BajaRon Sway Bar and give it a try. I find my stock sway bar efficiently & effectively handles turns, corners, accelerating, de-accelerating, slab stability, etc. However, my only experience is a stock sway bar.
    Thanx in advance for feedback, jon
    [SIGPIC][/SIGPIC]
    Mar 2008
    Allegan, MI
    If you find your stock swaybar is adequate, why do you want a replacement?
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Most folks are happy with the OEM bar; until they try Ron's!
    Think of how your bike tries to lean as you put it through a turn ...
    Now imagine what it'd be like without all of the leaning!
    Invalid Emails
    Sep 2012
    Clermont Florida
    Cool
    Also you can back off on the spring preload for a softer ride with Rons Bar all pluses with so little investment get it.
    That's what I did with mine...
    May 2013
    Bucks County, Pa-Phila suburb
    Default NO CONS
    Quote Originally Posted by figmotoday View Post
    As far as I can tell there are no "cons", Only "pros". (Except cost of several hundred dollars). I'm thrilled with my BajaRon bar!!!!(2012 RTS)
    I think that I might have seen 2 reviews that described the improvement as "minimal"...
    ...And it's impossible to please everybody!
    Invalid Emails
    Jun 2013
    Fair Oaks, Ca.
    Default Feel the same...
    Thanks for posting this. I feel exactly the same. My stock sway bar is fine in twisties and turns, but I keep hearing about the dramatic improvement when switching to BahaRon bars. I have an ST-L and the sway bars just came out (I believe) so not a lot of data/feedback thus far. It's not an option for me to try the sway bar out before purchasing it, but i'm wondering how much of a gain I will achieve with swapping out my stock 2013 bar for one of BajaRon's. Gotta say that i've heard nothing bu positive about the BajaRon sway bar though. I will be staying tuned for the responses.
    Active Member Web Runner's Avatar
    May 2013
    Houston, TX
    I felt the same way as you. I read almost everyone's feedback on the BajaRon Sway Bar and decided to jump on the bandwagon 2 weeks ago. I see from your profile that you have a 2012 RS SE5. My ride is a 2010 RS SE5. I am here to tell you that you will see a difference in the way the Spyder handles cornering and turning. After taking my Spyder out for its initial test run with the newly installed bar, I thought to myself "this is how it should have been all along". If you enjoy the feeling you get when taking corners, you will undoubtedly like it even more.
    As far as accelerating and decelerating, I did not notice anything since the purpose of the bar is to reduce body roll during turns/corners. So, it won't affect that. I'm not sure what slab stability is, but if you are referring to sliding or skidding across dry pavement during a turn, the bar will help keep both front tires on the ground.
    Hope this helps with your decision.
    2010 Full Moon Silver RS SE5
    Nov 2012
    Thanx to all for the feedback.
    Slab = interstate/multiple lane tollways
    Slab stability is my term for the control when riding @ moderate - fast speeds in heavy 4,5,6,7 lane chicago traffic with gradual-sharp curves.
    I have a blast doing all the leaning needed for various curves and the stock bar works great for drag racing. However, I'm close to getting the BajaRon bar with all positive reports on improved performance; also, gonna check on aftermarket sway bar warrantee issues.
    [SIGPIC][/SIGPIC]
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    I really noticed the difference when I trailered my wife's Spyder. Before we put on Ron's sway bar I could see the bike sway side to side. After we put on the bar and we trailered the bike there was almost no body roll when we hit bumps or pot holes. I can also tell riding behind my wife, especially, when it is really windy out. I know she is super happy with it.
    Instead of watching it in the mirror; think of how good it is from the seat!
    Very Active Member MMcc's Avatar
    Aug 2010
    Annandale, MN
    Default Sway Bar
    Everything positive everybody said about the handling with the new bar is probably correct. I have not tried any aggressive rying yet. Just letting the eyes heal after the surgery. I can say that I noticed a major improvement with the bar when ryding the 2 lane highways around home. The semi's that tend to move you sideways when meeting them is a thing of the past. Have not adjusted the Elka[s but will play with them in the near future. My feeling is go for the bar you won't regret it.
    Mar 2008
    Allegan, MI
    In that kind of traffic at freeway speeds what you will like most is the stability against wind gusts and buffeting. Passing a semi becomes quite effortless. You probably will get spoiled fairly quickly, because you won't have to lean into the corners as much. You still can, but the need is not there and you soon get lazy. On a long ride it can sure be less tiring, though...especially two-up in the mountains.
    -Scotty
    Nov 2012
    Thanx to all for feedback, I'm ordering one.
    This site rocks with all the help & support. The help/feedback reminded me of the saying - "I don't need to know squat, I just need to know WHO to ask."
    [SIGPIC][/SIGPIC]
    May 2012
    Champlin, MN
    I too am thinking about getting one of these, I've seen it is the must-have aftermarket accessory. I've had the Bumpskid for my RSS sitting around for a year waiting for me to get off my bum and install it; I figure maybe I should do both of these at the same time.
    Will the sway bar cut down on the engine stuttering at the current speeds I take turns from the VSS kicking in? I would assume if it ensures the wheels are firmly planted, that the VSS won't sense a stability problem and the engine wont be throttled back as much as it is currently?
    Current Spyder:
    "Can-Am Red"/Black 2015 Spyder F3-S with Heated Handle Grips, Gauge Spoiler, Fog Lights, 12V port, Akrapovic Exhaust, Driver and Passenger Backrests
    Previous Spyder:
    "Can-Am Red"/Black 2012 Spyder RS-S with Can-Am Comfort Seat, Comfort Grips, Rigid Saddle Bags, HID lights, Fog Lghts, 12V Accessory port, Trunk Liner, Hindle exhaust, Flash2Pass, SpyderPops BumpSkid, Side Grilles, Missing Air Dam, Air Management System, BajaRon Anti-Sway Bar
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    My wife noticed and said you don't lean into corners anymore. I told her I didn't need to. Still waiting for nanny to come calling I think mine might be sleeping.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    May 2012
    Champlin, MN
    Quote Originally Posted by Magdave View Post
    You don't need to lean at all? I assumed the spyder would be more stable, but centrifugal force combined with the fact you aren't actually attached to the spyder, you would still want to lean so you don't go flying off.... (your weight is carried straight down into a bike when a bike leans, but on a spider your weight wants to throw you off)
    Then again, I have an RS and ride aggressively in the turns, I've never ridden an RT but have heard they handle completely differently...
    Current Spyder:
    Previous Spyder:
    Jun 2013
    NE South Carolina
    Quote Originally Posted by dguisinger View Post
    Very
    few times do I lean anymore unless it is a sharp curve. I put a Utopia back rest on and just lean against it and squeeze my knees if needed. The RT probably handle like a bus compared to yours too.
    The GS/RS bikes feel like Mustangs when compared to our Crown Victorias...
    May 2012
    Champlin, MN
    Hahaha.... I hope that means they stick around after the ST cannibalized sales.
    Hmm, a mustang? That means they still need a spyder that compares to the RT like a Bugatti Veyron compares to a Crown Vic
    Current Spyder:
    Previous Spyder:
    Mar 2008
    Allegan, MI
    "Stuttering" in a corner is usually a result of too much throttle, too soon. Hit the apex before you crank on the throttle, and roll it on smoothly. In 90 degree corners straighten the bars before you hammer it.
    -Scotty
