Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 77
Thread: 2014's Coming
  1. #51
    Aug 2013
    Stafford, VA
    This close to introduction time, I would recommend holding off until you see what 2014 has to offer. If the 2014's are not what you want, there should be some good deals on 2013's, 2012's etc. I purchased a brand new 2011 RT A&C in July of 2012, saved a couple thousand, got a good trade in, and am very happy with the even though it was two years old (model year) when I purchased it.
    Lots of choice if you are not in a big hurry. Good luck on your hunt.
    Think I will wait then - dealer down by me is offering 2013 Spyders at invoice plus the rebate but I'm not in a hurry. I still need a license and I'm taking the driving course in a couple weeks.
  2. #52
    Registered Users joet82's Avatar
    Oct 2010
    Winlock, WA
    Quote Originally Posted by Double Trouble View Post
    If you ride a Spyder correctly you move into fifth gear around 65-70 mph when the Rotax is in the lower end of it's optimum power band. If you had a sixth gear you would be upshifting at 85-90 mph and that doesn't make a whole lot of sense.
    on my 09 RS, I have no problems shifting into 5th at 50mph. and that's when I'm casually going up through the gears. I don't really look at RPMs, but I use my speedo for my shift points. When I'm casually shifting, I go into second at 20, 3rd at 30, 4th at 40, and 5th at 50. same with downshifting.
    RS - 55K+ miles, F3 - 200 miles and counting.
  3. #53
    Jun 2010
    Las Vegas
    Quote Originally Posted by joet82 View Post
    You may have no problem but your Spyder might disagree with you.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
  4. #54
    Oct 2010
    Winlock, WA
    if I go below, I can hear it lugging, and obviously that's not good. but those are the marks I use, and I've never had an issue with it.
  5. #55
    Mar 2008
    Allegan, MI
    Whether it seems so to you or not, you really are shifting too soon. If you glance at your rpm immediately after the shift you will notice that it is below the recommended minimums for clutch longevity with an SE. Besides that, your Spyder is far from happy. It doesn't really wake up until 5,000 rpm. Hitting second at 20 isn't so bad, although the Spyder actually prefers a bit more, but the remainder are definitely too low...especially for 5th gear. There is no way on earth you can maintain over 3,500 rpm in fifth at that speed.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
  6. #56
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    You may not think so but your engine has to be lugging at 50 mph in fifth gear.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
  7. #57
    Quote Originally Posted by ARCTIC View Post
    I want a CVT transmission
    A CVT... I've actually given a lot of thought to that... Paricularly when talk turns to an all-wheel drive Spyder. Can Am has the powertrain and engine already running in their Commander 1000. All-Wheel drive AND the CVT to boot!
    BUT...
    The CVTs that we know and love won't work well in this application... CVTs are tremendously efficient; but only within a VERY narrow range of operaton. The current models don't offer a wide enough range of "gearing" to allow for a decent top-end. Currently; the fastest of the ATVs or UTVs on might run about 75mph...
    True; some of that is due to the manufacturers being terrified of what might happen if they turned them loose without limitations... but you're still not going to be able to add anywhere NEAR another 30 mph or so on top, and still have low enough gearing to get you off the line smartly...
    And have you ever had to replace a sheave after you've "grooved" it from too many dragracing starts?
    I also think that the drivebelt that is used in them might not survive the heat under the Tupperware...
    For the record:
    I've played with CVTs since the mid-sixties...
    I've changed flyweights, spacers, rollers, and springs up front in the primary clutch
    I've poiished secondary ramps
    I've changed secondary heixes
    I've played with the reduction levels in the chaincases...
    You end up moving the acceleration rates around; but it almost always costs you something in another place...
    But Doc would have a BALL with a CVT on a Spyder...
  8. #58
    Jun 2013
    LeClaire, IA
    Default 2014
    I'd say floor boards will become standard on SE5's with pegs becoming optional. New tinted windshields are a possibility for southern states.
    These are just guesses based on instinct.
  9. #59
    Doru the Destroyer-Spyder Photo Investigator docdoru's Avatar
    May 2008
    Clearwater, FL
    Sure, bring it on...
    2013 "Silver Dream" GG Taurus
    2008 "Silver Dream" Spyder RS
    Einstein's theory of drag racing: Time and Speed are Relative.
    Shut up and Race!
  10. #60
    You would have so many new variables to play with, that you'd never come out of the shop... Except to test the results!
  11. #61
    BUT...
    For the record:
    I am not mechanical so cannot discuss the above very well. My latest car (Subaru Forester 2014) has a CVT and I like it a lot. It has the power to get up and go and gives me about 31 mpg on top of that. I have seen some motorcycles with it offered--but have not had the opportunity to see how I like them. Had a 1976 Hondamatic 750--was that also a form of CVT? You just put it in drive and it would wind out like a jet.
    Registered Users KEBIE's Avatar
    Jul 2013
    Alabama
    Can someone message me the proper shift points. I see no fifth gear below 70 but what about before that? Thanks
    09 GS SE5
    20130727_151339 by Kebie05, on Flickr
  13. #63
    Quote Originally Posted by KEBIE View Post
    You should be shifting by tach (RPM's) rather than by speed or sound.
    Recommend: Shift between 5000-5500 rpms for the upshifts. That will put you at about 65 mph for 5th gear. Downshifting: You can let the downshift by itself if you want. I usually downshift between 3500-4500 rpms. The above, gives me a seamless, non clunky shift.
    Do you have an "ESSIE", or an "ESSEM"?
    The SE-5 transmissions don't like it when the rpms drop below about 3500 or so... Their clutches aren't fully locked up until then, and the'll burn the plates up!
    The SM-5 transmssions are the typical motorcycle style transmission; you can actuall run them at about any rpm level that you want without worrying about damage... but the bikes like to rev...
    Which Spyder do you have?
    The pre-2013 GS/RS models were tuned for less torque, but more horsepower. This tuning moved the powerband about 750 rpm or so further up the tach... They REALLY like the revs!
  15. #65
    Registered Users DoggyDaddy's Avatar
    Apr 2013
    Redlands, CA
    Default Just Spoke to a Local Dealer About 2014 Changes
    I stopped by Temecula Motorsports on Friday to kill some time between business appointments. I started talking to a salesman (who seemed quite knowledgeable about Spyders) about possible changes to the RT for 2014. He said that from what he has herd from BRP the changes will be minor since the 2013 was a fairly significant update. I have no idea if he is right or not but it seems to make sense. If I were to make a bet I'd say that the next significant update won't be until 2015 or 2016. Look at other bikes on the market, many of them go years without any major changes (Goldwings, Victorys, BMW's, etc.) only incremental updates. Unless there is some compelling reason to do a major update, why would BRP invest in the cost when the current machine is still state of the art and now (finally) becoming fairly reliable.
    Then again, I could be way off base!!
  16. #66
    What you've said makes about the most sense...
  17. #67
    Active Member Racy2's Avatar
    Jan 2010
    Bolton, Ontario Canada
    I rarely use fifth gear unless we are running in a 70-75 speed limit zone and my fuel mileage runs around 31-33 mpg. If the Rotax is lugged down under 4,000 rpm you will find it uses more fuel than if you run it in the rpm range where it is most comfortable and performs best.
    A Spyder is not like most bikes.
    You are right about a Spyder not like most bikes. Every car,truck, bike has more gears than they ever did in the past. Figure that out why and you have your answer.
  18. #68
    May 2013
    SW MO
    I'd like to see a 6-speed where 2-6 are the current 1-5 and first gear is geared so it hits the redline at about 30-35 MPH. The current first gear is good to about 55 MPH and doesn't get into the power band until almost 30 MPH. That's too high IMO.
    Silver Shadow
    2013 RT-S Lamonster Edition (vented windshield,
    NBV highway pegs, Two Brothers exhaust)
    Additional Mods: SpyderPops BumpSkid, Elka 1+ shocks, BajaRon Anti-Sway Bar
    A Veteran is someone who, at one point in his or her life, wrote a blank check made payable to “The United States of America,” for an amount of “up to and including my life.”
  19. #69
    Active Member condorflysu's Avatar
    Feb 2013
    Brampton, Ontario, Canada
    Quote Originally Posted by bruiser View Post
    Warp core.
    Cheaper on any fuel ... A Mr. Fusion to go with the flux Cap. Beer cans and garbage for fuel .. A empty 6 pack to the moon and back milage. I'd like to see BRP address the heat issues. 174 f crotch temps might limit the younger crowds procreation rates
  20. #70
    After reading DoggyDaddy's post, and remembering the major redesign of 2013; You'll get BNGs this year. and probably not much else while they work on the issues...
  21. #71
    arntufun
    Guest
    Those lucky enough to be coming to Spyderquest, will know about the 2014 Spyder.......... I will tell you that it has three wheels !!!!!
  22. #72
    So; you're having them deliver Holly's 2014 RT Limited right to the campsite?
  23. #73
    Aug 2013
    Stafford, VA
    Default BNG?
    Hi - What is BNG? Second question - will dealers sell the 2013 at a discount once the 2014's are released? I can buy a 2013 ST-S for 17.5 although I really want an ST Limited.
  24. #74
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    Quote Originally Posted by thedonva View Post
    Bng= bold new graphics
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
  25. #75
    Oh! Sorry ... moto-speak fo Bold New Graphics...
    Arctic!
    You beat me to it...
    Were you the one who had issues adding HIDs to your bike?
