Results 1 to 9 of 9
    Jan 2013
    Barrie, Ontario. Canada
    Default handle bar removal RTS 2012
    Is it a simple job removing the handle bar ? Is it just removing the four bolts at top of handlebar ?
    Need to run a few wires up through the handle bar and out through the little plastic piece in the middle of the handlebar on top.
    Thanks
    Dec 2011
    Gilberts, IL.
    Umm...not quite so easy. The black plastic "beauty ring" under the bars will prevent you from getting to the clips that hold all the wiring in place. You will have to remove the headlight cowl, headlight adjuster cables from under the side service panels, and the headlights. After doing this, you will need a magnetic 8mm socket on a small 1/4" drive extension, with a small 1/4" ratchet to access the four bolts (from underneath) that hold the shield to the bars. THEN you can remove the plastic under covers from the bars, and get to all the wiring, etc.
    Good luck. You may learn, over time, from working on your Spyder, that your swear word vocabulary is quite a bit larger than you thought.
    Sent from my AT100 using Tapatalk 2
    Default THERE IS A VIDEO
    Someone who was trying to make " RISERS " for the RT did a video of what is involved in the entire HANDELBAR set-up.....Try the archives ...or maybe this has triggered someone else's memory of the video and can provide more info.......It may have been someone who makes RISERS for the GS/RS......Mike
    RT-S PE#0391 SilverSurfer's Avatar
    Dec 2009
    Columbia, MD
    ... and here's the video:
    Default SPYDERLOVERS ARE GREAT PEOPLE
    Quote Originally Posted by SilverSurfer View Post
    This proves when you are a Spyderlover someone has your BACK.............Thanks Silver Surfer ..I knew someone would remember that VIDEO ...Mike
    Thanks for that video!
    It reminds me why I've not started playing with the bars at all...
    Jan 2013
    Default Thanks
    Thanks all for all your help. I decided not to remove the handlebar. I choose to run the wire to another area of the bike.
    Registered Users Robertsepolen's Avatar
    May 2012
    Milton-freewater, Oregon
    What I did was remove the upper side panel. Then I fished a plastic zip tied down through the hole where the plastic piece in the handlebars is and was able to reach over near the speakers with the zip tie. This will bring you close enough to reach most wiring options. What exactly are you installing?
    2015 SE6 RT-S
    Black/Red Special Edition.
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    It's an adventure! Also an education as you get to see parts of your Spyder that you normally wouldn't.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
