Results 1 to 23 of 23
    arntufun
    Guest
    Default Spyderlovers problem
    First let me say I'm not new and have been navigating this site for some time. I recently have discovered a problem and I'm looking to see if others are having the same issue.
    When I'm in compatibility mode I can hit return and make paragraphs (spaces down between next sentence) but I can not post full size pics in this mode. This means when I insert a pic, I used to be able to double click the pic and make it full size before I submitted the post. I can't do this now, it will only come up as a thumbnail.
    When I'm not in compatibility mode, I can post full size pics but I can not hit return at the end of a sentence to create a new paragraph......... I'm running Windows 7, and seems I now have Internet explore 10 (used to have IE9) and it ran perfectly until a month ago when IE10 was installed automaticly.
    ANYBODY ????????????
    arntufun
    Guest
    Also, when in compatibility mode, my user name and notifications are laying on top of one another.
    Check which Internet Explorer you're running...
    IE10 does some wonky things in here.
    YOu might just have to switch back to IE9
    Default Have to agree..!!
    have seen many problems with IE10 and all switch back and the planets align once again..!!
    Eastern North Carolina
    Yep. I found that out too. I disabled auto update as well. I'm using Chrome now.
    arntufun
    Guest
    Does anyone know how to get rid of internet explore 10 ???? My computer says I have IE10 running and I just went to download IE9 and it says I already have it installed on my computer ????? How do I get rid of IE10 ??????
    May 2009
    Connecticut
    I have Windows 7 also and to delete IE10 I think I just opened -control panel- Install/Delete a program- and picked IE10 to delete because 9 was the one that came with the computer?
    Sea Doo GTI-SE 90 Jet Ski!!
    arntufun
    Guest
    Quote Originally Posted by Sarge707 View Post
    Internet explorer/ IE10 is not in my add or remove programs, is it called something else ???????? IE9 doesn't even show up in there ?????
    PM Scotty about this; he talked me through an"IE10"-ectomy on mine!
    And I've also heard that he's a good cook, an excellent dancer, and he once saved...
    Dec 2008
    Syracuse, NY
    Randy,
    Check this out:
    http://news.softpedia.com/news/How-t...7-308998.shtml
    Two things:
    Don't use quotes around Programs and Features.
    Once you get to click on Uninstall an Update, it's better to go to the box in the upper right and type in Internet; you'll find it easier.
    I just went through the whole process (to see if it works) and I'm back to IE9.
    arntufun
    Guest
    Quote Originally Posted by wyliec View Post
    You are the man !!!!!!!!!!! Worked Perfect !!!!!!!!!!!!!! If anyone else has these issues follow the instructions in the link Wyliec posted and you will be back in business. I also took Bruisers advice and disabled Windows from updating again to IE10. Thanks Everyone !!!!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by arntufun View Post
    Go to the Control Panel, then to Add/Remove Programs. Uninstall IE10, reboot, and IE9 should work. Then go to Windows Update and make sure "Update Automatically" is not checked.
    arntufun
    Guest
    Quote Originally Posted by NancysToy View Post
    Tried that first but, IE10 and IE9 was not listed under add/remove programs in my operating system (windows 7). Every other Microsoft program was in there except for Internet Explorer. I had to follow the steps Wyliec posted to get the job done.
    That IE10 is an insidious program. I had the same problem and spent about two hours getting rid of it.
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    [QUOTE=arntufun;664715]Does anyone know how to get rid of internet explore 10 ???? My computer says I have IE10 running and I just went to download IE9 and it says I already have it installed on my computer ????? How do I get rid of IE10 ??????[/QUOTthe easy answer is go to a MAC. Your stuck with IE with windows, can't delete and still have a functional system. Use Chrome or another browser.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    arntufun
    Guest
    The weird thing is, this site was the only one affected in a bad way by IE10. All other sites and forums that I belong to ran fine. I'm guessing the host server company here is not fully compatable with IE10, but thats only speculating on my part ???????
    Invalid Emails
    Ormond Beach FL
    Cool IE 10
    Simple! Go to control panel add and remove software highlight IE 10 click remove and your done. Reboot on completion.
    arntufun
    Guest
    Quote Originally Posted by Bob Ledford View Post
    See post 8 and 14...........
    Motorbike Professor
    Mar 2008
    Allegan, MI
    You have to have "Show Windows Updates" checked.
    Free Thinking Member
    Apr 2009
    Southwest MI
    [QUOTE=IGETAROUND;664802]
    Like there has never been any problems with Safari? You MAC guys crack me up, right up there with the Toyota fanboys.
    Chattanooga TN
    Default Same probs with IE10 on Windows 8
    I have been having some of the same issues with a new Lenovo laptop that came with Windows 8.
    It had IE10 installed but it does not show up in either the Installed programs or Updates.
    but... in the Programs and Features tab an optionfor Turn Windows features on or off there is a checkbox option for Internet Explorer 10.
    When I unchecked this box, it uninstalled IE10 and rebooted with no IE to be found!
    Now I am using Chrome entirely for a browser and everything seems to work great. Just have to keep fighting off Windows Update wanting to install IE10 plus they will soon be pushing IE11....
    Jun 2013
    Texas
    Try using Firefox
