Guaranteed to Stop Belt Flap Vibration
Baker Built Air Wings has recently developed a new Belt Stabilizer that is guaranteed to solve your Vibration Problem or you can return it for a full refund. It sells for $195.00 and can be installed in about 5-10 minutes. I recently installed one on under 3 minutes. All Baker Built Air Wing Products come with a 30-Day Satisfaction Guarantee and a 1 year warranty on all parts & Labor.
Sincerely,
Bruce L Baker
I had it installed at spyderfest and it removed ALL my vibrations at various speeds and rpms now I have good, good, good vibrations....
I have to ask though. Since the belt adjustment is so critical, wont this thing make the belt too tight? What about warranty issues should there be a problem? I could see a dealer saying, "your not covered with this thing on". And what I mean by that is if the belt is too tight you will ruin the shaft bearing on the motor which is costly to fix.
Bob
RT-S PE#0027
In regards to the question about over tightening the belt, this product does not tighten the belt per se, it just takes the vibration that is naturally occurring in our belts, and lets the vibration be absorbed through the tensioner instead of being transmitted through our primary drive sprocket. It is a simple but brilliant idea and have not heard of anybody that has installed this, that hasn't had the vibration completely go away.
Sent from my SCH-I605 using Tapatalk 2
Back amongst the living May 2021
2022 RT Limited Hyper Silver
Out to Pasture:
2013 ST Limited , Black Currant
2022 F3L , Dark Edition
2021 RTL , Chalk Chrome
2013 RT Limited , Circuit Yellow Metallic
2008 GS SM5 , Millenium Yellow
2020 RT Limited Petrol Dark
2014 RT Limited Champagne Black
2012 RT Limited White
2010 Timeless Black RTS SM5
2010 Orbital Blue RTS SM5
2008 GS SM5 PE 1941
2008 GS SM5 PE2011
Answer to Belt Overload Question
Bob
Hello Bob,
Since the Belt Stabilizer only puts 8-10 lbs of pressure it does not increase overall belt tightness.
It only stops the belt from flapping on the bottom, Or loose side of the belt.
This belt Flap is what causes the vibration that you feel.
One of Indiana's Largest Can-Am Dealers,
RT Sales in Zulu Indiana installs these belt stabilizers on most of the Spyders that he sells.
They are convinced that they are very beneficial.
If you have any further questions, don't hesitate to ask
-Bruce
Where are these listed on your web site. I could not find them.
Figures I make this post and then find it. Ordering it now
Hi Bruce...If the cylinder wears our over time,or another part fails out of warranty,can a person buy individual pieces since they won't need everything?...Thanks
Sincerely,
Bruce L Baker
Will it work on 2013 RT models?
Baker Built belt tensioner with Spyderpops Missing belt guard?
I have the Spyderpops missing belt guard installed. If I install the Baker Built belt tensioner will it interfere with the belt guard? Will they work together? I assume at the maximum I would have to trim the belt guard a little, but I would hate to purchase the tensioner and have it not work. Any information on this setup would be appreciated. Thanks, Tom
MY MODS Spyderpops bumpskid & missing belt guard
Corbin seat w/driver backrest and passenger arm rests
CD brightsides & mud flaps w/tips, HMT running and brake light
Kuhmo Ecsta rear tire -- Ride-on in rear tire -- Tomcat mud flap
CD black shortee antenna -- Elka level 1+R front suspension
BajaRon's sway bar -- BRP's adjustable wind deflectors
Kuryakyn 3789 widow speaker grills -- Blue closed web Web-boards
Behind the mirror LED turn signals
According to Brooke at Baker Built, the answer is yes.
I have just installed both the belt tensioner and the missing belt guard on my 2012 RT and there is no interferance
Thanks, I'll put a belt tensioner on order.
