Results 1 to 13 of 13
    May 2013
    Bucks County, Pa-Phila suburb
    Default Help with tailight wiring color codes
    Tried doing a search but no luck. Does anyone know the taillight color coding for a 2012 RT-S: running light, ground, brake lights and turn signals. Want to add a set of hyperlites I have from an old bike.Thanks in advance, Bill
    Mar 2008
    Allegan, MI
    Orange = Running lights
    Black = Ground
    White = Brakes
    Grey/Pink = Left turn
    Brown/Yellow = Right Turn
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Active Member Johnny_Swindle's Avatar
    Jan 2013
    Ponchatoula, Louisiana
    Would this be the same for the 2011 RT?
    Quote Originally Posted by NancysToy View Post
    Black = Ground
    White = Brakes
    Johnny
    2015 RT-S (SE6) Special Series
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Johnny_Swindle View Post
    Should be the same across the board.
    -Scotty
    May 2013
    Stanton, ca
    Yep, that's the same wire colors as on my 2011 RT-S
    Bob
    2011 RT-S SM5 - Black
    May 2010
    Knob Noster, MO.
    Black = Ground
    White = Brakes
    Glad this came up, and Scotty replied. I had this combo for the RT, and now know I was wrong.
    White (or Black) = ground
    Brown = running lights
    Yellow = left turn/brake
    Green = right turn/brake
    Is it Friday yet? ... Oh yeah, I forgot. I'm retired
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    2014 RT - Testing completed
    2016 F3-T Audio package - Sold
    Bryant, Arkansas
    Quote Originally Posted by Blue Star View Post
    You are right, you are wrong.
    Cruzr Joe
    May 2010
    Knob Noster, MO.
    Default So let me get this straight..
    Cruzr Joe
    I was wrong, and is right that I was wrong, but now I am right?
    PS. sad part was I got the wrong colors from this site too. Just not from Scotty.
    Past bikes
    2010 RS - Sold
    2012 RT - Sold
    Mar 2013
    Maumelle, AR
    Ok, now I’m really confused! I recently installed a 2013 BRP hitch on my RT Limited and it has thesquare, four pin plug (female end).
    I was able to find the male end of the square, four pin plugand connected it to a flat, four pin female plug so I’d have a jumper to hookup to the trailer I’m buying (it has a flat, four pin male end). *** Shout out to Mini Trailer, USA*** Imatched the wires for the jumper… yellow, brown, green and white but it doesn’t workproperly.
    What did I do wrong?
    2020 RT Limited , Chalk
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Copperman View Post
    The wiring colors on the Spyder are not the same as the trailer harness wire colors. After the module, the 2013 harness colors are standard trailer wiring colors.
    Now to add to your confusion...the RT-622 harness colors may be different than either...and they may change colors at the conector, so they are not the same in the back of the trailer as they are at the hitch.
    Brown = Running Lights
    White = Ground
    Yellow = Left turn/brake
    Green = Right turn/brake
    -Scotty
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    Hooked up trailer to a 2013 RT . Matched wire colors and tested them for a match. Worked ok for about 1000 miles , modulate on bike died. Did the twice ): ended up bypassing modular , works fine. I think the modular gets too hot , because of new location under seat ! Prior models , modular was at rear of bike ! Engineering issue , again !
    Invalid Emails
    Dec 2012
    Tollison, AZ
    Default Tail light wiring
    Are these colors the same on an RS? spiderboy69@yahoo.com
    Very Active Member Desert Spyder's Avatar
    Oct 2008
    Barstow, California
    White = Ground
    French....
    Happy Spyder Owner
    States visited on the Spyder.
    And if we live life without a passion, then we're not living.
