tire pressure on non OEM front tires
Just ordered a set of Bridgestone Potenza for the RT. What PSI is everyone running who have non OEM tires? I would like to get a good starting point. Thx
TIRE PRESSURE
Well it depends on how many plies your new tires have....Generally speaking the more sidewall plies the stiffer the tire.....Also car tires usually have more tread plies which also helps them run flatter.....The OEM's ( fronts)with ONE ply side walls states 15 to 17 lbs.....I think a car tire would be fine at that pressure also...Mike
To many variables..!!
you can start at the oem pressure and then find yours. The tires have some ref's but you don't have the weight. Tire tread should be flat across, if arched up it is over inflated and center of the tire will wear faster, if sunken to low and the sides will wear faster. But some fine folks will come along and give you the pressure they are using..I still have oem tires..good luck..!!
2012 RS sm5
I'm running my General Altimax 185/60R14 front tires at 20PSI. Before the General's I was running the OEM front tires at 18PSI.
2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
You might want ot PM Firefly; he's been running Potenzas for a while now, and should have some good info for you!
I've been running these tires for about 2000 miles now. Set them to 20 PSI based on recomendations found here. So far I've felt no need to change. Love the tires so far.
2011 RTS SE5
Excellent advice!
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
I have mine set at 20 psi. Really nice tires so far.
Seems that 20 to 21 psi with auto tires is about right I've been running that for 13,000 mi now and my tires look like new I'm sure they will go 40,000 or more
2 happy happy spyders
Motorbike Professor
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Originally Posted by NancysToy
I suggest you use chalk, not caulk. Caulk, which is a sticky substance used to seal openings in buildings, would make a huge mess! Chalk, which is used to draw on blackboards (and sidewalks) is a powder. That is what you want.
u'r right Nan.... i must have been asleep when i wrote that... duh
Motorbike Professor
Sure would have made a mess!
-Scotty
