The only real heat I feel on my 2013 RSS is on my left leg, the right seems to stay at a comfortable temp. The left is not so hot that it burns or anything like that but if it were a little cooler it would be more comfortable on 100 degree days. I bought some exhaust wrap and water wetter and will wrap the left exhaust in the next couple of weeks.
Here is what I am testing out now. Rode a little today and was surprised on how much heat I don't feel. Fan kicked on and could barley even feel any heat at all. This opens up for the heat to escape in a large area instead of just out the side. I even sat in the garage while the bike was running and the fan on and still didn't feel much heat blowing on me. Instead of completely taking off the splash pan underneath I drilled 6 holes (1 1/8in).
Here are the guards. If you look under your spyder on both sides you will see these. Coz, helped me by stating that I should remove them but, I didn't like what it exposed so today I decided to drill holes. I will take some more pictures or you can PM me with your e mail and I will send some or maybe a video.
did you remove something near the radiator? it looks different. can't put my finger on it.
I did. The plastic piece that is supposed to redirect it out the side, I took it out and I am surprised at this point. Haven't tested in really hot weather yet so the question is still out on how it works. It was in the mid-high 80's today low humidity.
i don't recall anyone ever doing that before. let us know what happens when it's in the ninety's again. it would be great in colder weather.
Sure thing. Well, i went into limp mode the other day when it was hot before this mod and was doing 60 MPH. Changed the fuse in the fan slot and it never done it again. Who knows. Guess we will see.. Will keep everybody updated.
Its would be a good idea to send more pics., a video would be greatly appreciated, I am sure.
I guess increasing the flow path, does help, keep us posted.
I wrapped the left exhaust header pipe and its helping a lot , the left side was very hot to the touch and came up through the crack between the plastic and oil cooler cover now it gets on the hotter side of warm but can touch the plastic with no problems , I wrapped it about 4 time and it does help. Started at the first bend and went back to the last bend by the belt.
Well I am lucky as my plastic is not that hot. Warm to touch but not burning. I am hoping that the removal and hole drilling I done could resolve problems. I may go to the other side and drill 6 more holes after some more testing.
Just a quick update, today I will be shooting a video of what I removed to show you some of the differences. I still need somebody to test something for me if possible! Require no mods just wanted to see about air flow compared to mine. PM me!
Awesome.. Thanks for the share! I am uploading my video now and then will post soon to show a little more in detail to what I have accomplished. I am about to go out for a small ride, then to further my investigation!
Keep in mind that the bike is sitting still and imagine the air flow that is happening while the bike is moving, I do feel more heat is being pushed out and also out the left side as well.
That looks great . . . How does it work on a hot day?
works fine
I also used thermal wrap on the inside of the top block off plate and that has pretty much removed all hot air escaping (I also cut a large hole in the lower pan and covered it with grate to prevent anything getting kicked up under the bike
I hear a lot about heat on the right side. I have 2012 RT LTD and the right side is fine the left side gets a little warm. I also don't hear anyone say they are wearing boots over the ankle. I would like to hear about that. I have not been wearing boots and I think if I did I would not feel any heat. Might be uncomfortable in Texas it was 100 yesterday.
We have a 2011 RT and DO wear over the ankle motorcycle boots... the heat on the right side when sitting is downright hot... I may experiment tomorrow (have a week off, yay) and will post my method if it works out...
Best of luck, I am going to drill 6 holes on my left splash pan to see how it works out, more heat being pushed out is better .
Good riding boots and jeans. I have ridden in 115 degree weather and neither my feet nor my legs got uncomfortably hot.
2008 GS SE5 in 2008
2010 RT SM5 in 2011
I see and understand where you have drilled the 6 holes under your . My question is = How do you know if the hot air is flowing out and under your Roadster or is the cool air flowing into your Roadster?
I do not have my Roadster at hand to see and understand this very well now.
Where is the positive air entering the Roadster to cause the hot air to escape out of these holes?
These questions come from my experience in heat / cold and return air ducting in houses. One often thinks that a hole in the pressurized duct blowing air into your house will blow air out of that hole... when in fact it can be sucking in the air from outside the duct. The pressurized air flowing over that hole creates a suction through that hole.
