Results 1 to 25 of 26
    Jul 2013
    Alaska
    Question Cruise Control question...
    Just recently purchased 2012 RT Limited, so it comes standard with factory cruise control. Upon using the cruise control, set for 55 mph... works great. Coming into a 45 mph zone, I used the cruise control switch to slow down to the new speed but still keep it on cruise, and it was fine down to 46 mph, but when it hits 45 mph it drops out of cruise. I went back to the dealer and asked what was wrong and got the answer that it "might be dust/dirt on the speed sensor interfering with the cruise." I told them that the speed was correct as having gone through a radar setup for a construction zone that showed the speed was within 1 mph of the bike, also the speed on the GPS matches the speed of the digital display of the bike. They didn't seem to have any other response. Needless to say I'm not buying in on their response, so I thought I'd asked the experienced riders here a spyderlovers. If anyone has an answer I'd appreciate being able to go back and educate the dealer. Thanks in advance for all that are able to respond.
    Oct 2011
    Jacksonville,Ar
    Did you hit a bump when it kicked off? Some brake light switches are very touchy.
    Mine did the same thing when I hit a bump. When I would press on the brake pedal the switch would turn on with only 1/8 inch of movement. After having it adjusted no more problem.
    15 rt , yes Black
    Mar 2012
    Spokane, WA
    Cruise works on RPM's so if you get under about 2,500-3,000 rpm's it will kick off. So slowing in a given gear will kick cruise off. Saw this on spyderlovers a few weeks ago. And found this to be true.
    Jul 2013
    Alaska
    Default Cruise Control question...
    No didn't hit any bump.. was smooth road. Wouldn't re-engage until the speed was back up to at least 46 mph.
    Quote Originally Posted by samewok View Post
    Jul 2013
    Alaska
    Showie - thanks I'll have to give that a try. I was in 5th gear, not sure what the rpm might have been, but I'll check it out. I was expecting it to be like an auto that works on a certain min speed. Most autos are between 30 -35 for min speed.. regardless of gear or rpm.
    Quote Originally Posted by Showie View Post
    Jul 2011
    Mitchell, Ontario, Canada
    I am guessing that a 2012 RT Limited is a SE5. If so if you are in fifth gear and slowing and the RPM drops to a point that it senses the clutch slipping the cruise control will disconnect. At that speed you should be in 4th.
    May 2013
    Clinton Twp Michigan
    at 45 mph in 5th gear it probably is rpm related. I usually run around town at 45-50 mph in 3rd gear.
    Aug 2012
    Jacksonville, NC
    I would think it is RPM related. I can set my cruse at 22 in 1st gear.
    Jul 2011
    Default As per owners manual
    Jun 2010
    Las Vegas
    What the heck does that last sentence mean?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Aug 2012
    Jacksonville, NC
    You can use the throttle apparatus to increase speed to make the transition better.
    Jun 2010
    Las Vegas
    Quote Originally Posted by Wiredux View Post
    I must really be tired because that seems like a ridiculous statement to me. Not yours, Wire, but the BRP book.
    2010 RT- 622
    Aug 2012
    Jacksonville, NC
    Yes. I don't see the throttle as a lever either.
    Apr 2013
    South Carolina and Florida
    On my 2013 RTS SE5 the cruise works at any speed, even 25 mph. But, you have to be in the appropriate gear. At 55 I would be in 4th gear. At 45 I would be in 3rd gear. If you are not keeping the RPM's up, the clutch is not properly engaged and will wear. If you were at 55 in 5th gear and bumped the cruise until you reached 45 in 5th gear, you are probably lugging the engine, potentially damaging your clutch and the cruise will kick off. IMHO
    Invalid Emails
    Jan 2011
    I think what BRP is saying, although very poorly (french - english translation?), is that the rider may wish to increase engine speed somewhat when turning off the cruise control so that an abrupt compression deceleration doesn't occur. I find myself doing this occasionally in certain situations, although I don't recall ever reading that sentence in the past.
    Mike
    www.rtwrider.net
    Jun 2012
    Cumberland Cove - Monterey, TN
    It means there is no hysteresis in the control software and the switch functions as an on off switch. Which is dumb programming.
    Carl
    May 2013
    Stanton, ca
    Quote Originally Posted by quickster47 View Post
    Carl
    Well there kind of is. When in cruse the throttle spring pulls the manual twist throttle all the way back. So the cruise control does not actually move the throttle grip. However you can use the throttle grip to speed up above the cruise control setting and when you let go, it will drop back to the cruise setting.
    This is the same as how a car cruise control works. If you tap the break or turn it off, your foot is not on the gas peddle and you slow down. Same here with the spyder.
    Personally I use cruise all the time! It's like a built in cramp buster! Then again I use it on my cars all the time and it is a ticket saver
    FYI, I did hit a big bump once and it must have bounced the break peddle. That's the only time I have had it drop out of cruise control.
    Bob
    Jun 2013
    colville wa
    Feb 2012
    Portsmouth, Va.
    Default 3000 rpm minimum to set
    Cruise control must be at 3000 rpms to work. it will work in any gear as long as you are at least 3000 rpms. any that is what mine does.
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by AkWinter View Post
    You need to tell that guy that if he can't make up a plausible lie then the best thing is to say "I'm not sure, let me find out". I really hate when people just make up a lie when they don't know the answer to a question.
    JT
    Quote Originally Posted by jthornton View Post
    JT
    He's got to be able to think quicker on his feet than THAT!
    Jul 2011
    JT
    Jun 2010
    Ferndale, Washington
    If I shift to a lower gear the cruise control will turn off. Remember to keep the rpms at 4000 or higher.
    I think the issue also is RPM related. I use my cruise control a LOT here in AK and have never had any problems with it running at less than 45 mph. You just have to be in the correct operating gear and range. I recommend shifting up at 5000, and keeping the rpms in the 4500-5500 in any gear. For me, 5th is usually used for 65 mph and up highways.
    We have discussed dealers by PM--so I will leave it at that.
    Active Member Gunkandpudge's Avatar
    Nov 2011
    Hot Springs Village, Arkansas
    Default Thread: Cruise Control question...
    I have an RT SE5, 2010. I have found that at 45 mph the cruise control doesn't work. At 46 or higher it works fine. I live with it.
