Did they give me the right screw driver?
Hi all,
I just received my 3 piece net set from Value Accessories.
I am excited to install them. the screws on the inside of the side bags on my RT use these funny star-headed screws ( I know you know what they are called). In the tool kit, they provide a cool double-sided driver with that kind of head. Only, it seems to small to turn the screw. If I do, I think it will strip it.
Anyone know if they included the proper driver, or do i have to go out and find one?
Thanks!
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
it requires a T20 Torx Bit Driver
Get a cheap set at Home Depot or Lowes or some similar hardware store
Cruzr Joe
They are Torx screws. A set of screwdrivers is not very expensive and I suggest you get a set.
2018 F3 LIMITED
Torx set...
Sears sells a very nice "T" handled ratchet set that includes Torx™ bits.
Dave
Never leave well enough alone! (Raymond Loewy)
I only looked in my tool kit under the seat once, does it have Torx drivers in it? I'm away from the Spyder so I can't look...
JT
JT
Yes, Screw driver handle with double ended shaft.
2018 F3 LIMITED
