Results 1 to 22 of 22
    May 2013
    Stanton, ca
    Default DIY Air Conditioning "Plausable"?
    So I have seen a few jokes about this (especially from Bob) but in reality I think this could be doable.
    Imagine if you will....
    Your riding jacket which is mesh to allow air in right now. But...... Suppose it has an attachment on the back for a hose. Kind of like a space suit. There is a small lightweight air conditioner somewhere that feeds cold air into the jacket and causes a positive pressure pushing hot air out of the mesh jacket.
    I have no idea about BTU's etc... but it seems this could be done with todays tech in a small light weight unit efficient enough to provide upper body comfort on hot rides!
    I am not joking here really.... It's just an idea and to see it ripped apart by those that know air conditioning and what it would take and if it would be at all feasible....
    At work they call me an "idea man". Not all my ideas are good but just throwing this out there for a "what the hell".
    Bob
    Jun 2012
    Concord, NC
    ...But when the cold dry air, meets the hot sweaty air, you'll get thunder showers in your jacket.
    Yes, it is plausable. I'm just going to sit back and watch this one.
    Invalid Emails
    Jun 2013
    Someplace north of Houston, Texas
    Check this out:
    May 2013
    Stanton, ca
    Quote Originally Posted by 54spyder View Post
    Check this out:
    Crap... someone stole my idea
    Seriously it was an idea I had thought of myself today (due to a Bob joke) but it appears I was not the first
    Bob
    May 2013
    Stanton, ca
    OK so I went to the web site and checked it out. My idea is different. Seems they are pumping chilled water through the vest. My system would be cold air and the attachment to the jacket could be a retrofit to any jacket.
    So my idea still stands
    Bob
    Apr 2012
    USA Andrews, TX
    Check this out.
    http://entrosys.com/
    J. D.
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    In the 80's the Army tested such a system for helicopter pilots in combat aircraft. I was in the test and we walked around the flight line with such a system and then plugged into the aircraft when we strapped in. The Army eventually scrapped the idea due to cost, etc. However, I can tell you it worked well.
    2021 Can Am Spyder Sea-to-Sky
    May 2013
    Stanton, ca
    Quote Originally Posted by TexasSpyder View Post
    Check this out.
    J. D.
    OK, OK.... but we can do better than this old "tech".
    Some ideas:
    1) It is retrofitable to any jacket or vest.
    2) It is "wind" powered to the compressor! Why not use the energy we are creating when in motion! Yes I realize at long stops it will stop cooling but how long a stop?
    3) The power generating windmill could be behind the radiator to power the compressor and maybe using the "can" design like a product already, divert the hot air?
    4) Since we are talking an RT for me, it must have 2 up hoses.
    More ideas?
    Bob
    Very Active Member YPILOT's Avatar
    Aug 2009
    Johnson City,Tennessee
    Lets send some of that cold air to the throttle bodies.
    "Stupid is as Stupid does"
    Don't Drink and Drive or Ryde!
    Each Day is a Gift
    Jun 2013
    Quote Originally Posted by YPILOT View Post
    And under the seat on the 2013 RT!
    Aug 2009
    Quote Originally Posted by Hayfield View Post
    Cars have air conditioned seats so why not spyder seats ?
    Each Day is a Gift
    Jun 2012
    Concord, NC
    Actually, you can probably find a small 12V compressor - possibly the kind they use in the little coolers you plug into the cigarette lighter of the car. I don't know how cool it would be, but it seems that if it keeps soda at a nice 45 degrees, and is small enough to just fit a six pack, you may have the workings of a "cool suit"
    Jun 2012
    Concord, NC
    May 2013
    Stanton, ca
    Quote Originally Posted by shelbydave View Post
    If I am thinking the same as you, those are called Peltier "coolers". They use electricity and transistors to make a hot and cold side. They can only do so much like best case 20 degrees below ambient or so.
    Here is info on them:
    http://en.wikipedia.org/wiki/Thermoelectric_cooling
    I don't think that will be good enough and they are highly inefficient by todays standards. They are usually used to thermo-cool chips that require cooling like a CCD Chip used in Astronomical cameras (I have a few of those My "other" hobby). They simply cannot handle large volume cooling requirements I am talking about.
    However, thanks for throwing up IDEAS! This is what makes things happen!
    Bob
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Wet your T-shirt, don your mesh jacket, go fast. At the next gas stop, repeat. There is no reason to make this complicated or hard.
    Oct 2009
    Virginia Beach, VA
    I agree . Wet T's, except for those wide boddies, cover please. The more the T's are wet the better.
    Scotty,
    Why'd you have to mention wet Tee-Shirts?
    I'm not going to be able to concentrate at all in the office today!
    Jun 2013
    Wayne, WV.
    Post
    Scotty,
    And I don't DARE post any of the mental pictures that have already been conjured up! Lamont would stomp me into the ground...
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Bob, you obviously neglected to read the part about putting on the mesh jacket over the t-shirt.
    Back to the AC units...
    It's very do-able, and Dave is also working on a new Palace for Teddy that will have it...
    You might just want to see what directin he's taking on it.
    It would seem that if you could direct the unit's output to whatever location it was desired, (Rider, Passenger, body ductwork...); you'd have a very marketable item!
