I have the Diamond R Chrome Trunk Rack with the Diamond R Armrests. I also have the BRP Travel (Half) Cover. The cover is a little tighter and a little shorter but still works fine. The antanne hole still fits perfectly over my shortee antanne. The difference may be your Corbin Armrests...not sure about that. An advantage to the Diamond R Armrests is that when not in use they will fold inward towards the center of the passenger seat. This gets them out of the way of the cover.
But good luck on your customized cover. You're fortunate to have such a talented wife. Be sure to post a pic.
Not down side..!!
looks like just more farkeling....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
This "Adventure In Farkling" actually is a good thing; it helps to keep your brain nice and limber!
It just shows to go you that your farkleing has reached a new Zen level.
Carl
2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
Looks good
RT-S: HMT brake light, mud flap lights/turn signals, Trailer hitch, Garmin 660 GPS, Ride-On, Travel cover, LED Mirror turn signals, LED trunk lighting, RGB ground effect lighting, BajRon anti-sway bar, to be continued ......
Member of the WSR (Woodstock Spyder Riders)
