Results 1 to 16 of 16
Thread: Lock handlebars
    Active Member Doug's Avatar
    Jul 2013
    Brights Grove, Ontario, Canada
    Default Lock handlebars
    manual says put key in the ignition, turn handlebars fully left or right, then turn key to lock position, and then take out key. Well am I missing something, I seem to be getting a lot of resistance to turning handlebars left or right, what do you do just wrenched it hard or what.
    2017 F3-S , circuit yellow
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by Doug View Post
    The power steering is not on and the tires want to resist twisting on the cement, asphalt or whatever. Of course it's going to be a bit stiff. Put some muscle in it.
    2018 F3 LIMITED
    Jul 2013
    alright, I'll get the wife on it
    Very Active Member ARCTIC's Avatar
    May 2012
    IOWA
    you could always just start the bike and turn the handlebars and shut it back off if your wife cannot handle it
    2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
    Jul 2013
    i guess you have to be careful you dont ask a stupid question on this site, sorry!
    Very Active Member Buttsy's Avatar
    Mar 2012
    London, Ontario, Canada
    Don't panic normally stupid fits in quite nicely around here?
    2011 RTS SM5
    Default Here's what you do..!!
    whenever you pull in and know you want to lock the bars, turn them before shutting down. Make it easier but can be done dry...!!
    ​2012 RS sm5
    washington state
    Make sure you turn the tire against the curve. JMO.
    2012 Spyder RT SE5 Brake pedal mod
    Jul 2013
    Default NICE ANSWER
    Thanks Chupaca, nicely put, now don't feel to bad
    IMO: There is no such thing as a stupid question. Now, when it comes to answers, you sometimes hit the jackpot.
    Apr 2013
    Baton Rouge, La
    Default Stupid questions
    I agree with Akspyderman, around this sitethere are no stupid questions but there sure are alot of smarta$$ answers.
    North New Jersey
    Default Locked handlebars
    I can always get my bike locked! But I always struggle to get them unlocked? Any easy suggestions ?
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Quote Originally Posted by Stharbor99 View Post
    Start lifting weights and build up your guns?
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Mar 2008
    Allegan, MI
    Sometimes it helps to wiggle the bars while turning the key, or turn harder toward or away from the stop. The direction may vary.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Registered Users donec's Avatar
    Jun 2012
    Central Texas USA
    When you go to unlock the bars push the handlebars farther into the direction they are turned to take the pressure off the locking pin. Which will allow the key to move the pin easily.
    2013 Pure Magnesium Spyder RS-SM5 Cal Sci medium clear windshield, R-35 hard sided saddlebags and fitments rack, 2013 Can-Am Spyder ST Limited Embroidered Stock Seat, Trunk opening spring, fire extinguisher, Passenger backrest and rack, Added side mirrors, Handlebar bag.
    North New Jersey
    Quote Originally Posted by donec View Post
    Thanks for all the feed back on getting the bars unlocked!
