Simple Floorboards
I have installed some simple floorboards based on some I saw while at Homecoming. Made of 1/8" steel with 2 90 degree bends and some non-skid tape. These are bolted to BBP highway brackets in the front and the drivers peg in the rear.
I'm looking for some swap meet floorboards to finish the job, but for now they are working great!
Rubber mats Added
Reason: New Info
The glass is half full.
Mike Murphy
Happy Spyder Owner
Re: Simple Floorboards
Cool!!!
Where'd your shifter go?
Very Handy Member
Where is your shift lever? Will the floor board interfere with it? What about on the brake side, will there be enough clearance for hard braking? Just some thoughts and questions.
With Christ all things are possible, so live life with no fears and no worries.
Happy Ex Owner, Hopefully future Spyder owner again.
Pastor Deb Tangen, Missions Director and short term missionary.
Originally Posted by LittleJohn
Cool!!!
Ditto... Looks like it could be comfortable but where is the shifter as already proposed...
Shifter? What shifter? I have the special one-off SM5-E model. You didn't get the memo? ;D
Klicktronic Electronic Shifter
I have a prosthic left leg & nerve damage in my left arm and hand. Hence the "one-off" model to accomadate my "Leftover Abilities"!
The brake works just fine.
Mike Murphy
Happy Spyder Owner
Very Handy Member
Way to go Mike!!! Thanks for the info and the photo from the other side.
Registered User
:bigthumbsup: :bigthumbsup: :bigthumbsup:
[URL="http://www.esicycleproducts.com/"]
Simply Awesome... :bigthumbsup:
Very Helpful Member
Adapt and overcome! Very nice!
Great job Mike!
Does the klictronic operate the clutch... or just shift between gears without the clutch?
Looks similar to the Pingle setup.... but yours is hidden inside.... which I like!
Nice Job Mike.Parts for this mod standard off the shelf.?
great job. possible another pic of right brake side from above?
The klicktronic system came with everything needed except a small length of angle iron we used to mount it to the spyder framework.
My clutch is on the right handlebar (no grip in my left hand) with the shift buttons mounted on it. The clutch is needed to start from a stop and I (almost) always use it to downshift, upshifts can be accomplished by rolling off the gas and shifting easily.
The floorboards I had made at the local hardware/building supply store. Just took them a pattern from 1/8" x 1" steel bent in a vise and had them fab it from 4" wide 1/8" stock. When/if I find some nice floorbords from a bike, I will make the support out of 1/4" stock welded instead of bent and a bit less wide. The only issue I have with the setup so far after 400+ miles is that my right foot gets hot from lack of fresh air flow. I think this would be solved by a narrower support w/ regular type floorboards, but its not a real big deal 'cause I don't use the right one all the time, as I do with the left (prosthic leg side).
Here is a photo from above. The brake does extend sidways over the floorboard, but there is plenty of clearance for full travel.
Mike Murphy
Happy Spyder Owner
Thank you. Excellent work.
Thats a pretty cool idea you had for floor boards. And it looks like there is plenty of room for the shifter to work. You just may have given me plans to make my own. Thanks
And those are great looking Highway pegs. What parts did you use?
Great job on those other mods.
The highway pegs are mounted on the brackets from billetbikeparts.com (link on main page here) with "Longhorn Dually" pegs from Kuryakyn.
The floorboards use these brackets as the forward mounting point. They slide on top of them and two holes are drilled to attach them w/ 1/4" bolts and lock nuts. The footpegs are drilled and attached w/ the same 1/4" hardware.
I probably should have metioned this earlier. Sorry for the brain lapse. :-[
Mike Murphy
Happy Spyder Owner
The floorboards use these brackets as the forward mounting point. They slide on top of them and two holes are drilled to attach them w/ 1/4" bolts and lock nuts. The footpegs are drilled and attaced w/ the same 1/4" hardware.
Nice job, its nice to see people not only put there personality in to there but adapt and over come there limits, Awesome Man!!! I like those cruiser pegs I am going to order those for my
:bigthumbsup: SPYMAN
PE #2735
RUBBER SIDE DOWN SHINY SIDE UP!!!!!!!!!!
Never ride faster than your Angel can fly...
I added some Rubber Mats to the Floorboards and updated the origonal post with the picture.
Actually, just now I added another layer of rubber to raise it up 3/4".
Mike Murphy
Happy Spyder Owner
So, I'm curious......
Anyone else tried this? After 4000+ miles, they are just awesome to ride with.
I use them most of the time.
Mike Murphy
Happy Spyder Owner
SpyderLovers Founder
Funny, I saw a set like these yesterday at the Spyder BBQ and the guy said he had a "Patent" on this idea and had sold it to BRP or was going to. I thought I had seen this before and did a Google search on "Spyder Floorboards" and found your post.
Rubber mats Added
I like it.
You could drill some holes in the front-vertical part of the bracket to let the air through, bonus - it will save a little weight and lose almost nothing strength wise.
Very Helpful Member
Same here. dltang told me about the "patent" conversation later that afternoon. Actually, I saw two or three different versions of this idea at the Gatlinburg event.
One of the designs used two down rods from the footpeg to the floorboard instead of being a solid piece of metal.
Shameless bump for newbies
Mike Murphy
Happy Spyder Owner
