Results 1 to 25 of 25
    Oct 2007
    Default 911 Hood stuck closed
    On vacation in Myrtle Beach. Wifes purse in front trunk 2012 RT, hood is stuck closed> Any Ideas??????
    Jun 2010
    Las Vegas
    Here is another thread on the subject http://www.spyderlovers.com/forums/s...=opening+frunk
    Try pushing on the trunk while you turn the key Good luck
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Super Senior Member
    Sep 2009
    Green Cove Springs,Fl
    my 2012 rt limited front trunk also stuck (lucky my purse was not in it) eveything was tried>>happened on Sat & we had to wait till dealer opened on Tues & they had to replace a part>>just read where 1st Coast Power Sports will be open in St. Augustine morrow(may have to go to a dealer if u can not get it open Good Luck
    2012 RT Limited Lava Bronze
    Inspector Gadgets cupholder & rear deck brake light
    Invalid Emails
    Alberta, Canada
    Had this happen to me on my trip and by pushing down on it while playing with the key and electric release it finally opened. I also had trouble closing it one time and had me puzzled and what it was is my Spyder was park off cambered and when closing the lid it did not line up properly at the latch and would not close. Just by pushing it to one side while latching all was good. Later tried on level ground and all was OK there too.
    Default Let's see..!!
    if the electric release is not doing it even when pressing on the hood at the latch point, press on and off while some one presses the key in and turns to the left (counter clockwise) good luck..!!
    ​2012 RS sm5
    Jun 2010
    Las Vegas
    If you get it to open by pushing down on the lid while turning the key be sure to check the trunk liner gasket before you close it again. I have found that if the rubber gasket is not perfectly lined up the trunk may get stuck. The other cause is overfilling the trunk.
    2010 RT- 622
    May 2013
    Stanton, ca
    Quote Originally Posted by SpyderAnn01 View Post
    Exactly what has happened to me a few times now.
    Bob
    Oct 2007
    Default Still Stuck
    Tried all suggestions still stuck>HELP
    Registered Users SpyderDen's Avatar
    Dec 2010
    Space Coast Florida
    Quote Originally Posted by GreenRider View Post
    Maybe you should pick up the check. Sorry.
    Have you tried both locks, key switch and electric?
    What is happening when you either push the button, or turn the key? Is it making any sounds (clicking?), or are you being met with silence?
    Registered Users carajony's Avatar
    Dec 2012
    Central Florida,, Orlando
    Happened to the wife the other day. She came to me saying that the "stupid trunk" wouldnt open on her RS... I went over and after pushing it in a few times and playing with the key it opened. I looked in and saw what the problem was... She had a helmet, 2 jackets, her purse, and the spyder full cover in there... I was like "no wonder"... But kept that to myself....lol... Not stupid...lol...
    Oct 2007
    Default Hood still stuck
    Bob, there is no sounds at all. It just won't budge. Tries spraying a little WD 40 in but no help.
    Oct 2007
    Default Stuck Hood
    Quote Originally Posted by Rattigan_Roger View Post
    I assume you've tried everything.
    Sometimes our frunk gets caught in a no mans land between locked and unlocked.
    Here's a really stupid question.
    Did you try a nice hard pull?
    Yes pulled as hard as I thought was prudent. Did not want to break hood,
    Mar 2008
    Allegan, MI
    Pulling usually won't do it. You have to push down hard on the center, top where the latch is, while simultaneously pushing the ignition key down and turning it counter clockwise. If you feel resistance while turning, that is good...the cable is working. From there on out it is a matter of getting the latch to release. Sometimes banging the lid with your hand while the key remains turn will do the job. Anything that pushes up on the lid interferes with the latch release.
    If you get it open, check carefully for weather stip that is pulled off the flange, a trunk liner improperly installed over the weatherstrip instead of under, a bent microswitch arm, or a trunk too full of stuff. Lubricate the latch mechanism to make things work easier. The latch may also need to be adjusted...particularly if the electric release doesn't work readily.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Okay; it doesn't say here, but I'm guessing that you've got a 2012 RTS; right?
    And you've tried the pushbutton?
    With the ignition on?
    With the bike running?
    And you've tried using the ignition switch to unlock it?
    With somebody firmly pushing down over the latching area?
    Can you push down on the funklid, and then try to just move it from side to side a bit? Is there any play in there so that you can move it around a little?
    If you can; try unlocking it again using all of the above methods...
    Otherwise... it looks as if it might end up being a trip to a dealership for something a bit more creative...
    Good Luck! Please let us know what happens next!
    Oct 2007
    Default Great News Vacation Saved BY Red Line Motor Sports
    The hood is open, thank you for all the suggestions. Went to local dealer in Myrtle Beach "Red Line Motor Sports and theyb saved the day. Fast service, good peopel and great work. Yhank You all for your help.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    And that was going to be my suggestion bought mine from them
    Glad to hear that you're back up and running!
    What'd they say was the problem??
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    Agreed.
    First, please say that the dealer told you what happened or what the problem was and its fix. Second, please relay to us (FOR FUTURE REFERENCE) what the fix was.
    These are the things that help when one of us in the future might run into the same problem.
    Chris
    Glad to hear you got the frunk open.
    Registered Users joet82's Avatar
    Oct 2010
    Winlock, WA
    And the problem/solution was???
    I had the same issue and my problem has been that both of my cables broke. First the seat cable, and currently the truck cable is sitting where I can reach it till I can get home again.
    RS - 55K+ miles, F3 - 200 miles and counting.
    Dec 2012
    Inquiring minds want to know... howd they do it? any damage?
    Very Active Member Flanker's Avatar
    Apr 2013
    Michigan
    And I was just on my way to FedEx my SawzAll down to Myrtle Beach.
    OK.....................so I wasn't the only one with helpful thoughts. I was gonna run with a 12 gage and buckshot.
    2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
    Nov 2012
    North Las Vegas, NV
    We were headed to WV for vacation and I read on this site to make a little fail safe for the frunk with a small wire from the latch to the oil tank area. Since I had lots of stuff off for the ron bar install and oil change I put the wire on to release the frunk in an emergency. Didn't need it but it was there. Thanks to the people here and this site.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Did you take any pictures of just how you've got that attached under the hood?
