Thanks Thanks:  3
Likes Likes:  1
Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Member ICE's Avatar
    Dec 2007
    Belmont, CA
    Default bleeding brakes with vacuum system
    Has anyone successfully used a Mity Vac bleeder or similar system to bleed the brakes on the Spyder?. If so, what would be the proper bleeding sequence?
    Eponymous Member Bob Denman's Avatar
    Grahamsville, NY
    I'm not familiar with the commercial setups... but they sure should work just fine!
    I had a Polaris ATV that would just get so airbound that you couldn't pump up anything with the lever...
    Solution? I'd hook a Turkey baster up to the bleed valve (with it's bulb fully squeezed and compressed)
    Open the valve, release the bulb, and it'd pull the fluid down through the system slicker than snot!
    So if a nincompoop like me can figure that one out; it's got to work!
    If my Ass is in the saddle: my head is in the clouds!
    2010 RT A&C...............2014 RT-L...................2018 10th Year RT-L
    ............Gone; but not forgotten!!................... The Latest, and Best!
    Jun 2011
    Near Lexington, NC
    [QUOTE=Bob Denman;651076] Solution? I'd hook a Turkey baster up to the bleed valve (with it's bulb fully squeezed and compressed)
    QUOTE]
    Bob, sounds reasonable, but will you test it out on your spider and let us know if it work?
    ted
    Favorite Dealer: Winston-Salem Honda/Can-Am, N.C.
    White 2014 RT SE, Vin 0568 (Sold Aug 16 after purchasing a Slingshot)
    2ndnew tire at 24Kmi..Gen hp43 205-60-15
    New Ignition sys & keys in early '14
    1st Dess Module replaced at 15K
    2ndDess Module replaced at 20K
    Utopia back rest
    Lamonts footpegs
    TricLed brake lights,
    Wired for Gerbing
    Ronbar installed
    Garmin 750 with Ram Mount
    Spyderflaps Mud Flap
    Dimple Drain Plugs
    Tri-Axis handlebar
    Rear brake pads @24K
    Grahamsville, NY
    Ummmm...
    I've not actually looked into what might be necessary to bleed the brakes on Fawkes yet...
    I will say that my RT's brakes work great; I'm thinking about ordering some EBC pads for a bit of an upgrade when the time comes to replace the OEMs...
    SpyderLovers Sponsor jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by ICE View Post
    I use a Mity Vac on my bikes but the Spyder doesn't have enough mileage yet. I'd recommend downloading one of the service manuals so you can have the bleeding instructions at hand as there are about 5-6 pages of instructions. IIRC you need to disconnect the battery when bleeding so BUDS won't go into alarm for low pressure.
    JT
    JT's Air Filter/Dash Mount/Dash Power/Hitch Fender, SpyderPops Heat Block/Rock Guard, Misty Mountain Sheep Skin, Baker Belt Stabilizer, Baja Ron Swaybar
    Grahamsville, NY
    Disconnect the WHAT?? And lose all of my radio presets, clock settings, audio settings, and whatever else when the World goes dark?
    Ride Forrest Ride! effgjamis's Avatar
    Jul 2008
    Kissimmee, Florida
    Well ????? danger,,,, danger,,,, danger,, ID 10 T is approaching..
    Original FL XPRESS 5
    Only way To go. 1 mile on 40gr.
    Grahamsville, NY
    "ID10T" is my driver's license number!
    May 2013
    Stanton, ca
    You wont loose your radio preset disconnecting the battery.
    JT, I always read if you do your own break work (like flushing, etc) you have to have buds to clear codes?
    Does unhooking the battery actually work?
    Bob
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by finless View Post
    Bob
    Bob,
    I've not done it on my Spyder yet, I just did a quick review of the process in the service manual and it does say to check pressure with BUDS hooked up so I assume if you check pressure with the battery disconnected you won't trip the BUDS Nanny. I'm not sure what would happen if you pump the pedal with the battery connected and no pressure. One thing for sure if the battery is not connected BUDS must fall asleep after any caps run out of juice.
    JT
    May 2013
    Stanton, ca
    I have always done my own break jobs on most my cars. When the time comes I sure would like to do it on my Spyder. Mechanically it does not look hard at all.
    So if you ever do it yourself and it works, it would be great to write it up so those that want to save money can
    Thanks!
    Bob
    Grahamsville, NY
    Well THAT'S a relief!
    You have no idea how much trouble I had figuring out how to stuff them into the radio the first time...
    Feb 2013
    Poplar Bluff, MO
    Thanks!
    Bob
    It will be 8500 miles from now for me...
    JT
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    Mark replaced my pads and bleed the brakes on my 2009 RS...we had to go to dealer...hookup to BUDS...$50....but if we ever get the ST back on the road and to the point that I need brakes...we'll try to unhook battery and see what happens
    Save the Pink Flamingo...in the pink...
    Blue = states visited on 2009 RS
    Pink = states visted on 2013 ST-Limited & RS
    Orange = visited as passenger
    Green - never been
    Active Member skeetshooter's Avatar
    Jun 2008
    alabaster al
    Default Bleeding Brakes
    I just changed my brake fluid and bled the vcm.As long as you don't turn key on you won't get any codes.Every thing works perfect.I have a 2008 gs
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by skeetshooter View Post
    Can you amplify on the procedures used? Some of us have been tempted to give this a try but are hesitant. Did you start with a certain wheel and work your way around? What tools?
    Any info you can provide will be apprec.
    ted
    Utopia back rest
    Lamonts footpegs
    Wired for Gerbing
    Ronbar installed
    Dimple Drain Plugs
    Tri-Axis handlebar
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Quote Originally Posted by ulflyer View Post
    ....and we're gonna ride, we're gonna ride.....
    ride like the one-eyed Jack of Diamonds, with
    the devil close behind,.....we're gonna ride....
    Jun 2008
    alabaster al
    I used 1 friend 1 quart dot 3-4.I sucked the old fluid out with a turkey baster then filled it up with new fluid.We started on left front stuck a piece of clear tubing over bleeder valve my friend worked the bleeder while i worked the brake peddle.We pump until we got clear fluid.We then did the right front then the back all the same way.Just be sure bleeder valve is closed before you let brake peddle up each time.The vcm is hard to get to, went in on left side pulled left panels off to get to it.The bleeder valve is on top it is hell to get clear tubing over bleeder valve.It would have been alot easier to take the trunk off but it can be done without it.Be sure to keep fluid near full when doing it you don't want to get air in system.I
    used just about the whole quart,took about 1 hour 1 1/2 we had to stop and drink a few shop supplies.Its easy to do just watch what your doing.
    May 2013
    Stanton, ca
    Thank you! I am saving this post until the time comes!
    Bob
    Senior Member 2 Stricklands's Avatar
    Hardy, VA
    Post I have disconnected my battery several times - no problems
    I have 1 2011 RT SE5. I have not had to bleed the brakes, but disconnecting the battery should not be a problem. I have disconnected mine several times to add relays, switches, etc. No Codes and nothing needed reset.
    When all is said and done......well it must be time to ride~
    2 Stricklands, Steve & Barb
    2011 RT AC, SE5
    Trailer for Travel and/or Golf Clubs
    Power outlet up Front
    Floorboards
    Voltmeter replacing old gas gauge
    Oil Pressure gauge replacing old temp gauge
    Turn Signals on mirrors
    Feb 2013
    Poplar Bluff, MO
    Just reading the service manual this morning and like skeetshooter did the bleeding sequence is:
    Left Front
    Right Front
    Rear
    VCM
    They have you do all kinds of things and some I don't understand and some make sense:
    remove front wheels
    remove the calipers and position bleeder at highest point
    detach lift cylinder and passenger switch from seat
    unplug low pressure switch connector and brake light connector
    detach brake fluid reservoir and move to outside the footrest
    Ah here is the note: the previous steps are required for the hoses to run completely down toward the master cylinder.
    Then they go into installing clear hose on bleeder valves and bleeding the brakes...
    JT
    Grahamsville, NY
    ... You do the Hokey Pokey, and you turn yourself about...
    Jun 2014
    south florida
    Quote Originally Posted by jthornton View Post
    Left Front
    Right Front
    Rear
    VCM
    remove front wheels
    JT
    I just read the manual. I think the sequence in removing the reservoir ios so you don't spill brake fluid on the plastic
    2018 Champagne RTL
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by ahh-cool View Post
    When I took my 2011 RS-S SE5 for the 14,500 mile maintenance. The tech said that he had a better way to bleed the brakes. When I got the bill to pay there was a note that said there was a problem with brakes and I had to pay $500.00 more to have it done the right way. I put my Spyder on the trailer and took it to another Dealer. The Dealer that tried to screw me over is no longer in business. The power of the Internet is great.
    Mike
    Very Active Member Gray Ghost's Avatar
    Sep 2013
    Harper, Texas
    I haven't done my spyder yet, but there is no reason I am aware of that a mity-vac wouldn't work. They aren't that expensive if you shop around, you don't have to have anyone assist you with the job, and you can use the same tool to bleed/flush the brake systems in your other vehicle. A vacula works even faster but costs a bunch more.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
