Results 1 to 18 of 18
    Aug 2007
    Greeneville, TN
    Default 2013 RS-RSS-ST-STS-ST Ltd Sway Bar In Production
    Test Pilot reports have been very good on the Prototype 2013 sway bar so I have ordered production to begin. I hope to be shipping them by the end of next week if all goes well.
    This bar is specifically designed for all the 2013, RS, RSS, ST, STS and ST Ltd. Spyders. Price will be $215.00 delivered. If you would like more information or would like to order this sway bar kit (or anything else I carry), just email me at fyredad@hotmail.com.
    Thanks again to my volunteer Test Pilots. They are the greatest!
    Registered Users Five-O's Avatar
    Feb 2013
    New Jersey
    Nice....
    Jun 2010
    Las Vegas
    I'm sure that anyone who orders one will be glad that they did. They really improve the handling.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    What is different between the '12s and '13s just curious.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Magdave View Post
    Quite a bit. Bar length, bends, mounting location and method. About the only thing the same is bar diameter and Heim joints.
    Active Member Tanshanomi's Avatar
    Mar 2013
    Missouri
    How does the thicker swaybar that comes stock on the 2013 RS-S compare to this one? I am referring to thickness/stiffness.
    2013 RS-S SM5 [His] • 2021 RT Base [Hers] • 1977 Bultaco custom roadster • 1974 Harley-Davidson/Aermacchi 350 SS
    Default Way to go Ron..!!
    great job keeping up with the changes.
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Tanshanomi View Post
    My sway bar for the RS, ST line of 2013 Spyders is quite a bit stiffer than the RSS bar. Originally I was not going to make a sway bar for this model series because of the RSS bar being offered by BRP. But several customers purchased that bar and were not satisfied with it and asked if I'd at least look into making a heavier bar.
    After doing testing it was clear that a stiffer bar gave a much improved ride so I now have a Custom Performance sway bar for the 2013 RS, RSS, and all models of the ST. They have been a big hit.
    Registered Users gottago's Avatar
    Jun 2013
    colville wa
    Quote Originally Posted by SpyderAnn01 View Post
    2013 RT-S se5, C/D HMT third tail light( r/b/t), Ram Cup holder, TRICLED front fender LED's (r/t), C/D Bright sides (r/t), Bajaron sway bar and metal heim links, TRICLED mirror turn signal LED's, ISCI tall dual flag holder, BackOff LED license plate frame, "Rufus" (stuffed 20" Bulldog) real one wants nothing to do with bike. Honel tri bag for dash, recordingguy25's (SL handle) custom mud flap ( didn't want plain old square cut mud flap. Spyderpops critter gitter. Gremlin Bell
    Sep 2013
    Maine
    Quote Originally Posted by gottago View Post
    Do you make it for the RT ? 2013
    Sep 2013
    Houston
    Default Update on centering device for 2013 bar?
    Any development on collars or other device to keep the 2013 bar centered properly? My dealer remarked about it at my 600 mile service yesterday. The end links are in a bit of a bind as the bar shifts to the left. So far, no signs of problems but its not right. Seems collars like you supply on the older year bars would do the trick if machined the correct size for this installation.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2013
    North Bergen
    Default yeah
    Cool... I need to wait till they fix the few little issues with my ST-S like the Gas smell...
    Sep 2013
    Houston
    Quote Originally Posted by Baseball79ST2013 View Post
    Good luck with that. The gas fumes are normal operation according to BRP. Until the EPA gets involved this one is not likely going to get fixed.
    Jul 2013
    North Bergen
    Default Is crazy
    Is crazy but BRP is saying the reason this is happening is because we are riding under 5rpm at all times, is not the machine is us that we don't now when to change gears or ride the motorcycles at the correct RPM's.
    Aug 2007
    Greeneville, TN
    I am looking into this and will have a retrofit for affected Spyders soon. The problem only exists on some 2013's and was not observed on any of the prototype test Spyders. Nor has it been an issue on any Spyder until recently.
    The Sway bar on the 2013's should not need a limiting device because there is plenty of room for movement and sway bars are naturally self centering. There must be some variance between Spyders causing some to run the sway bar to one side.
    Sep 2013
    Houston
    The bike cannot be above 5000 rpm while sitting in traffic. It is BRP that does not know how to fix the problem, or more likely even have a way to experience and verify the problem. I invite them to Houston to find out.
    Jun 2013
    NE South Carolina
    There must be some variance between Spyders .
    For understatement of the year on the 2013's
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Aug 2007
    Greeneville, TN
    Unfortunately, you make a VERY GOOD POINT!
