Results 1 to 25 of 44
    May 2013
    rockwall
    Default Helmet Storage...
    So since I can only fit one helmet in the frunk, and can't fit the other in the rear compartments, I am curious about using the Helmet tie downs under the seat?
    Seem like someone in the know would be able to snap that piece of plastic right off. Also since the strap is not long enough, whats the best helmet lock cable?
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Have you tried putting one in the right-hand saddlebag? I found that if I laid the Missus' helmet on it's side; it'd fit!
    Apr 2013
    Weaverville, NC
    My wife and I have the Shoei Neotec, you can only fit one in the front and we put the other in the right side storage. Unless you are using it for something else, put the helmet in so the top is to the outside.
    Jan 2013
    San Diego area
    Default helmet storage
    right side and the frunk are it we have modualar helment and if I open the visorI can put 2 in the frunk
    Mar 2011
    Washington, D.C.
    Since my RS frunk often looks like the backseat of a hoarder's car , I can only fit my helmet in there, and only if I shove everything at the bottom down. So, when the GF rides, I just keep her full-face helmet on the seat, but I run a combo bike lock (that I keep stowed in the bottom of my frunk) through the helmet and loop it through the passenger hand-holds. The lock also works in a pinch to keep a riding jacket on the bike in the event I don't want to wear it in to wherever I'm going, just loop it through an arm and walk away.
    Active Member 2 Cruysyn's Avatar
    Nov 2011
    Broken Arrow, OK
    Quote Originally Posted by kepople View Post
    We've been using a pair of 1" D rings on the long strap and the hooks under the seat.
    Baja Ron - Dimple - Ultimate - Lamonster Garage - K&N - Smoothspyder - Amsoil - Hiflo - FOBO - Spyderpops
    Sena - Dynaplug - Shoei - Tourmaster - Garmin
    Feb 2013
    The Woodlands, Tx
    Master Lock Python is keyed with an adjustable, braided steel cable that gives you all kinda options for locking down items on the or anyplace else. Runs $10-15 depending on what cable size you want.
    Still small enough to easily store in frunk when not in use. Plus, you get Master Lock quality to keep the bad guys away, or at least looking elsewhere for something to steal!
    RT-S PE#0180
    Oct 2009
    St. Joseph, MO
    Quote Originally Posted by CruiseRT View Post
    My wife and I have the same helmet. Mine is an XL and her's is a M. I fit BOTH in the front compartment provided we have nothing else in there. Requires placing them in oposite (one facing up and the other down. Tight fit but it works for us.
    Apr 2013
    Weaverville, NC
    Quote Originally Posted by frank3 View Post
    I'll have to try that.....
    Default Cable locks..!!
    wife and I have HJC modular helmets and if we have stuff in the frunk (both fit there) we use a kryptonite retractable cable lock. Small combination locks. Several companies make them you can pick and choose. Can lock helmets jackets etc..good luck..!!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Those helmet hooks are much tougher than you would think. It would be very difficult to snap one off. Some helmets will fit, while some will not. You have to fasten the chin strap as loose as it will go to have a fighting chance. My Scorpion works easily this way, my Arai is a bit of a struggle, my Fulmer strap was too short. One alternative is to loop a long, heavy ziptie, put it through the D-rings, and use it as an extension. The big zipties take 50 pounds or more force to break, and work well in this manner. If they can use them for handcuffs, a helmet should be a piece of cake. Another good extension is a small cable lock like a gun lock. Good extension loop, or lock right to the grab bars. As was also said, the rught saddlebag will hold most helmets if laid on their sides.
    Active Member GuitarPlayer's Avatar
    Waterloo, IA
    My Arai XL Signet Q fits fine in the right saddle bag. I do have to lay it on it's side.
    Tony
    2017 Red F3T
    Mods
    Lamonster RIP Floorboards
    Lamonster H4 LED headlights
    Lamonster LED Fog Lights
    Lamonster LED White and Amber Fog Ring
    Lamonster Show Chrome Fender kit
    Lamonster Drink holder
    Lamonster Dual Power Plate with large X-Grip
    Lamonster F3 Driver Back Rest
    Lamonster Lid Lock
    Baker Air Wings Luggage Rack
    Jun 2012
    Central Texas USA
    I put a machine screw at the edge of the Frunk attached to the small piece that goes around the fuse box. I pulled it out and on the side away from the fuse box there is plenty of room. I drilled a hole and tried using a pop rivet to hold the hook but the pop rivet just pulled out of the plastic. So I drilled a larger hole and put a machine screw with 2 nut one on each side of the plastic. I hook the "D" ring over the screw and close the Frunk. Holds quite well.
    Invalid Emails
    Ormond Beach FL
    Default Helmet storage
    The way we do it:
    1. Saddle bag style:
    A. Clean everything out of the bag.
    B. Reduce the helmet to its smallest configuration. Reposition anything that is moveable to make it as small as physically possible.
    C. Stand looking at the bag with the lid open. Turn the helmet to where the front faces forward. Insert helmet with the top facing out. Try to close the bag lid. Did it close?
    1. If yes experiment using a helmet bag, gloves, etc until it won't. Then remove the "won't" item and your done.
    2. If no experiment with turning it 180 degrees or any other way you can think of!
    2. Trunk: pretty much the same as 1a, & b.
    3. Frunk:
    A. See 1a & b.
    B. insert # 1 into space except lay on its narrowest side. Insert # 2 the same way. Try to close lid easily. Not necessary to fram or slam! Did it work?
    1. If yes. Try inserting some other storage items.
    2. If no. Try turning the bottom on its "top" and the top on its "bottom."
    4. If nothing works say "ding it we tried."
    (layout changed on me sorry about that)
    When I'm feeling lazy; I use a handgun cable-lock. I just hook it to my Diamond-R armrests!
    May 2013
    rockwall
    I will try, but niether fit in the right side saddle bag.
    I have a Shoei Qwest xxl and she has a Shoei RF1100 L. It Almost fits in the saddle bag, but it wont close...
    After reading the manual which says you cna fit a helmet in each compartment, I guess I should have assumed they meant a bicycle helmet :-)
    Nov 2012
    Macon, GA
    I think if someone wants your helmet, it will be gone, regardless; however, to keep from tempting someone who would otherwise leave it alone, I would secure it via the tiedowns and whatever strap extender you decide on. It's funny, but I sometimes hang my helmet, which does not have any D-rings on the strap, beneath my son-in-law's GW on his helmet locks. All anyone has to do is unsnap the strap and walk off with the helmet. Haven't lost one yet. ;-)
    Jun 2012
    Central Texas USA
    Quote Originally Posted by gnirtsnod View Post
    If it doesn't have any D-rings or similar how do you plan for it to stay on if your in a wreck?
    Nov 2012
    Macon, GA
    Quote Originally Posted by donec View Post
    Funny - it's got a fastener that connects to two side straps together but no D-ring that's fixed to either strap that would require cutting the strap to remove the helmet from a lock, thus... "All anyone has to do is unsnap the strap and walk off with the helmet."
    Apr 2013
    Mesa, AZ
    $20 for 2 pair of black handcuffs from Amazon and I just handcuff them to the passenger hold bars. Works great.
    Jul 2010
    Huntsville, Al
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    Ilove how y'all have all tehse great idea's for RT's but those of us with RS's don't have much. I have a bif melon XL RF 1100 Shoei and it is all that will fit in the Frunk. If iw try I can get my jacket in there with it. If my daughter rides with me we have to do something else with her helmet. I am liking the idea of attaching it to the passanger grab bar. I just need to find the best solution for that. By the way handcuff's look like a great idea but one key fits all( just throwing that out there.) thanks for some really good idea's in here guys, this is why I hang around and read.
    Bill
    Jul 2010
    kansas ottawa
    the man that said use a gun lock is the least coast you get one with ever gun and they are free from most police and sheriff stations,yes free and there strong check it out.
    Invalid Emails
    Ormond Beach FL
    Default Another idea
    Go to your neighborhood fishing tackle and ask them to help you make a pair of miniature sling type cables you would have experiment on the length. Cable leader is plastic coated and they normally crimp them to make loops.
    To use them all you should have to do is pop the seat loose. Insert a cable half a length thru the dee rings then hook both loops over the helmet hangers and shut the seat assembly.
    a roll of cable wire, a bag of crimp sleeves if my memory serves me well should run about$10. And make you 10 or more cables.
