tire pressure
evening everyone what air pressure do you run in your tires. looking at the manual i read 17 pounds in the front and 30 in the rear, did i read this right. they said the tires are made special for the spyder so i am just wondering if i read it right. THANKS
Little checking..!!
There are a lot of threads on tires, tire air pressure etc here you can read. You can start with the pressure suggested in the manual and on the bike ( on the swing arm left side) then play with it as you see fit. Depending on your ryding style, weather, weight (solo double, trailer, cargo, stock or after market tires etc.) you may want to adjust the pressure...in time you may see wear patterns indicating too much or to little as well..lots of variables...
We run 18/20 lbs front and 28/30 lbs rear...
2012 RS sm5
2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
Motorbike Professor
Depends a bit on the model and year of Spyder. The RS seems to like around 20 F/28-30 R. The 2010-2012 RT does well around 17-18F/26-28 R. The 2013 RT and ST...and maybe the newer RS, likes a bit less in front 15-17. That's what owners seem to prefer. Start around these points and experiment to see what you and your Spyder like best. It costs little to nothing. Remember, recommended tire pressures are measured cold.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
our 13rt really likes
20 in the fronts and 28 rears. Seems to tighten up the front, 3-5 psi is noticeable in the front...
Lets ride!!!!
Tire pressure
19 front, 28 rear on my RS.
2010 Full Moon Silver RS SE5
I run 17f/23r on my 2013 RT-S. Seems to work for me and my style of riding and the wear bars on rear tire don't show up as quickly. But, like I read experiment with them for the best for you.
16 front, 20 rear..after running higher and wearing center tread out on 3 rear tires. Present Pirelli P4 with 4K show no discernable wear at 20 lb.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
tire pressure
2013 RT
19/28. Started with 16/30. The more pressure in the front seem to help the darting around. May lower the rear more if the wear shows more in the middle.
Need to find me some of that 78% nitrogen.
We don't know what we don't know...
2013 RT Limited
2012 RT-622 Trailer
I got it at Wal-Mart...
Pure nitrogen does not expand like our normal breathing air.(78% nitrogen, 21% Oxygen, Co2 and a few other things)
2013 RT Limited
2012 RT-622 Trailer
Nitrogen
Okay; so who's running pure nitrogen?
18/25 in mine (only about 78% nitrogen though... )
LOL! I've found that breathing a 78% nitrogen mix is good for my health! The USAF has used nitrogen for years in aircraft tires - less pressure fluctuation from temperature changes and less leakage than compressed air. Nitrogen is a larger molecule than oxygen. The oxygen molecule actually leaks through the tire, over time. Compressed air is also fairly "wet" as there is water vapor in it. Nitrogen is dry due to how it is produced, and is also inert, where oxygen contributes to . . . (ready for it?) oxidation! Your metal rims will last longer, as will the metal in the valves, if you use 100% nitrogen. I am looking for someplace local that will fill my tires with 100% nitrogen. In the meantime, I'll stick with the 78% mix!
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
It's one of the few items Wal Mart has that isn't made in China. Their air quality is too bad to use it for anything, including breathing.
