EBC brake pads
I'm going to have a brake job done soon and I just wonder how the EBC pads that Baja Ron sells are vs the BRPs? Ron has always been honest with me but to hear from those that have applied them would be nice.
Happy Spyder Owner
States visited on the Spyder.
And if we live life without a passion, then we're not living.
I put a set of Ron's EBC pads on the rear of my '12RT about 2000 miles ago. No squeal or chatter and I stop when I press the brake pedal...guess I installed them correctly. I do think I'm getting more brake dust on the rear wheel with the EBC pads then I did with the OEM pads. Not a biggee...I clean 'er up at least weekly.
I had installed the EBC rotor and brake pads on my 2010 shortly before I traded it in. My old rotor was pretty well shot from driving last summer with no brake pads while towing my trailer. Don't ask Anyway, I was happy with the new pads and the rotor. No squeal with the EBC
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Question: Ron has mentioned that a clip needs to be moved from the OEM pads, over to the EBCs...
Can anybody throw a bit more light on this issue and process?
Each pad has 2 clips on the back side. You will need to remove them and put them on your new pads. Pay attention to the orientation of the clips, they go on a particular direction so the clips will grab the post in the center of each caliper piston. Take your time, be very careful with the clips, if you lose or break one it will cost you some serious cash to replace because they only come with a set of new oem pads.
SpyderLovers Sponsor
There are 2 small spring clips on each front pad that holds them in place. They clip to a pin on the piston. They are pretty hardy and I've never broken one. You can lose them if you let them shoot off somewhere. I've had customers say they've broken them and I have to take their word for it. It may be they were pulling them off in the wrong direction, I don't know.
But with a little care I don't see any problem with re-using them over and over again.
The EBC pads do not come with spring clips. The BRP pads do but buying the pads is the only way to get them.
Happy Spyder Owner
Good product..!!
They work very well. I have had no problem with the stock pads so it's a toss up. If your doing it yourself you can use what you want. Some dealers only install oem products some will install what you want..good luck..!!
Thanks for the explanation on those clips!
I'm clumsier than any 17 of you put together; couple that with the visual acuity of a mole, and I'm going to have to give one a bit of thought...
The clips are really no big deal. Just wrap the caliper in a rag when you pop them off and you'll have no problems.
Or stick them inside a big ziploc bag before you do it. Easier to see through than a shop rag.
