Tree Sap
I have a spot of tree sap on my new vented windshield. Does anyone have a miracle solution for me, please.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
Motorbike Professor
Don't use anything alkaline or abrasive. I'd try Plexus, Dawn dish soap, Goo-Gone, Go-Jo hand cleaner, or WD-40 (in an inconspicuous place first), or maybe even just real hot soapy water.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Turtle Wax bug and tar remover. Get the sap pretty warm first by letting the Sun hit it for awhile. Then put a paper towel soaked in the above product. Don't rub let it soak. Then using a soft cloth with more product gently wipe it off. It may take several applications.
formerly pman2011
I had some tree sap on my fender and used a heat gun to heat up the tree sap to remove it. I had the heat gun on a low settings.
[B]
2018 Intense Red F3T (See About Me under My Profile for mods)
2010 Timeless Black RT-622 Trailer
2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
Sorry to hear the news.
The above is probably the best route.
If you need external heat for this, I'd suggest a hair dryer instead of a heat gun.
There's less likelihood of doing thermal damage if you use a hair dryer.
We should get together some time soon.
For a change, let's try riding together without the monsoon.
IBA #47122
2020 RT Limited Asphalt Grey
Sorry about the comment about letting it sit in the sun to warm up! I just realized that you live in Ct! LOL Here in the Sunny South we have Sun, Heat and all that goes with it, no need for heat guns or hair dryers too humid and hot!
SAP!
I have a cottage in Ontario, Canada that has pines that are 100 feet tall, we have shelters to park under to help with the sap problem, but if you don't park under them, well you get the picture, I remove the sap with boiling water, use gloves and hold a rag over the sap and soak the rag, repeat this until the sap softens, then wipe it off , might have to do this a few times but it always works for me.
Dave
2011 Spyder RT Limited, drive daily (except when it's snowing)
2012 Honda Fury VT1300
1974 850 Norton Commando, drive daily, praying that it keeps running!
2009 Goldwing GL1800 AD, traded in
2009 Suzuki M109, (fast bike), traded in
2011 Nissan Murano SL, S, ride to work
Tree Sap
Best method is crisco or butter. We have used it for years to get it off our hands, feet, cars, etc... Works great !
2013 RS-S Neutron Green/Black, Shark RSR2 helmet, Shark Evoline 3 helmet, Sena SMH20, Corbin Seat, Wheelchair Rack, TricLED fender lights, TricLed Underglow kit (green), Trunk Liner, STL Handlebars, Web Boards Driver Floorboards, backrest, BRP Saddlebags, ISCI Handbrake
Motorbike Professor
That's one home remedy I just have to try!
-Scotty
Senior MOMENTS Member
Tree Sap
I use to cut wood to heat my house with and often would get tree sap on my hands.
I would first scrub with cooking oil on my hands then use dish washing liquid to remove the oil.......VVVUUUUUWWWWWAAAAALLLLLLAAAAAAAAAA Spick N Span clean like a babies bottom
If it Feels Good, Do It !!
Too Much Is Just Enough !
2011 RS~S Pure Magnesium / Black ~M~
Murphy's oil soap and water or pine sol have both worked for me in the past.
MODS 2013 - Ultimate, Remote / LED Halos, Pete's Dash kits , Elka's!
2011 RT A&C-SM5 - Orbital Blue (mine)
Xenon Lights, Polk speakers (4), 5-LED lamps, fog lights, Sypderpops grills, OGB grips, TIPS and CHANNELZ lights. Seal FLRBDS, Two Brothers Muffler, ZUMO 665 w XM, Gloryders, HMT Brake.
2012 RT-LTD SE5 -Lava (hers)
MODS: Spyderpops chrome grills, TIPS and CHANNELZ lights, HMT Brake, Seal FLRBDS, Gloryders, OGB Grips
