Results 1 to 20 of 20
    Invalid Emails
    May 2012
    Locust NC
    Default Sway Bar and shocks question
    I have a 2012 RSS. I am hearing all the talk about BajaRon Sway bar and Elka shocks making a big improvement in the handling, mostly from the RT group. I am wondering if anyone with a newer RSS has made this mod and what the results were.
    Ron came out with a bar for the RS sereis first; there's a lot of folks in here who've bought them.
    I don't recall ever hearing anything but praise for his bars.
    Try the bar first; you might not even feel the ned to change the shocks!
    Mar 2012
    NJ
    Do the bar, skip the shocks. The Fox shocks you have are already a nice improvement over what a lot of us started with...
    Danbury Connecticut
    I totally agree!
    The most imprpvement per dollarcomes from changing the sway bar.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Very Active Member bullant12's Avatar
    Oct 2010
    Somewhere out there...
    Here is the way to see it:
    Anti-Sway bar= handles curves and turns
    Shocks= handles road pavement conditions
    You can do both, but the sway bar is the cheapest way to go, especially if you have Fox shocks. In fact, my wife changed her stock shocks on her RS-S to 2012 RT shocks and loves it!
    May all your encounters with the law begin with the words: "nice trike!".[/B]
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
    Besides; it might free up some money for some OTHER farkle that you can't live without!
    Very Active Member MidLifeCrisis's Avatar
    Apr 2012
    Gilbert, Arizona
    Quote Originally Posted by bullant12 View Post
    I'm going to add one:
    Shock relocators
    Registered Users Some Guy's Avatar
    Apr 2009
    Lansing, MI
    My 08 GS has the anti-sway bar and 2012 RT shocks. I love the way it handles.
    Number One: 2008 Yellow GS SM5. I love my Spyder.
    Number Two: 2012 RT-S Limited (the poop colored RT) I still have Number One, but Some Girl made me buy Number Two...
    Default Part one..!!
    we have a 2012 RS and installed the BajaRon sway bar. This is the most significant change in handling we have seen. We still have the stock shocks and re-adjusted to have a real fun machine. I hear the stock RT shocks make it even better and elkas as well. Expensive and we don't feel we need more at the moment. Maybe later on (part two)..
    ​2012 RS sm5
    Invalid Emails
    Sep 2012
    Clermont Florida
    Thumbs up
    Hi i have a 2012 RSS with Fox shocks that i had set pretty firm between 4 & 5 when i had the stock bar and in the wind or being passed by a semi i felt like i was being pushed to the side since i added the Ron bar i have backed off the shocks to maybe the 2-3 setting and it rides smooth and handles well in the curves and nolonger gets pushed side to side,i now can have a more soft and comfortable ride and feel more stable in turns i for one suggest getting the new sway bar and ride like u stole it.
    Mike
    Oct 2010
    Quote Originally Posted by MidLifeCrisis View Post
    Shock relocators
    The shock relocators would fall under the definition of shocks since it is an mod and a improvement.
    Previously owned:
    GOS member (Girls On Spyders) pslawing's Avatar
    Jun 2012
    Kings Mountain, NC
    Good assessment. Where do u think the relocators fit in??? I have the sway bar only. It made a huge difference.
    Invalid Emails
    Sep 2012
    Clermont Florida
    I think the sway bar is more for the handling and the shocks and relocater deal with how it rides on uneaven roads and small pot holes with all installed u should have a verry good handling and smooth ride.
    Mike
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by pslawing View Post
    The relocators give the shocks more leverage advantage over the suspension, essentially making them stiffer both in dampening and spring rate.
    The shocks do several jobs, one of which is to work with the sway bar. As you enter a turn the shocks help to slow the rate of motion or lean (they have a dampening effect). The trick is to get the right amount of dampening from your shocks without making the ride stiff or harsh.
    The sway bar transfers weight from the outside wheel to the inside wheel, flattening out the turn and increasing tread contact with the road. The Sway Bar also transfers some weight to the rear wheel.
    All of this reduces lean and increases traction. The same thing happens in cross winds or when passing a large truck at freeways speeds.
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by danlnc View Post
    I have a 2011 RS-S, with the BajaRon Sway bar it made a big improvement to the handling in the corners and a smooth ride on the highway. The improvement of the shocks on the 2012 RS-S all you should need is the BajaRon Sway bar. Try the sway bar first and if you the rougher flatter racing ride add the Elka shocks. That's IMHO.
    Mike
    Quote Originally Posted by Some Guy View Post
    Tell us the truth; Did you buy Number Two, just so that you could swap the shocks over onto Number One?
    Active Member Jharpo's Avatar
    Mar 2011
    Hudson, Florida
    Cool Same Here
    I did exactly the same on my 2009 GS. Great difference and I only wish my 2013 ST handled so well.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Jharpo View Post
    2013 ST Custom Sway Bar coming soon....
    Active Member SpyderSue's Avatar
    Near Estes Park, Colorado
    I posted a similar question a couple of weeks ago, and followed the advice of the fine people on this forum. Had the Baja Ron anti-sway bar installed this afternoon, and rode back up the mountain to my house. Wow, what a difference. Nice and flat around corners. I still have the stock shocks - may do the RT conversion and the relocater, but for now going to enjoy the new ride. DO AS THEY SAY! DO AS THEY SAY!!!
    Registered Users Y Blue's Avatar
    Mar 2011
    Illinois, US
    I have an '09 GS and we did shocks from a 2011 RT first and then later added the sway bar. I think mine needed both : ) I'm not sure if an RSS with the already better shocks would benefit as much from the shocks, but the sway bar is awesome.
    Y Blue
    -Ruth K, Hoffman Estates IL
