Results 1 to 12 of 12
    Invalid Emails
    Feb 2013
    California
    Default Our Spyders gauges change each time you start them...
    We are on two 2012 RS 's (Semi-automatics) One time they will be on Total mileage, next time on Time, next time on something else. Is there any way to keep them on Time or do we just have to continue to keep punching M to what we want every time we start them?
    You should have to manually change it from one function to the other. If the gauges are doing it by themselves, you may have something electronic going on.
    western Colorado
    You should have to manually change it from one function to the other. If the gauges are doing it by theirselves, you may have something electronic going on.
    1? Are you pushing or holding the mode button when starting? This may cause it to change
    Default Have to agree..!!
    tap it once then start...otherwise you may have a cluster problem..!!
    ​2012 RS sm5
    Apr 2012
    Arizona
    I believe its the mode button also as mine does it sometimes too. Always at start-up time.
    Mar 2008
    Allegan, MI
    You could be holding the MODE button too long, pushing it again, or one of them could be stuck (usually the one on the display).
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Invalid Emails
    Feb 2013
    California
    Default Mr. Bones got my question...I guess I wasn't clear in my question for the rest of you
    Quote Originally Posted by MrBones View Post
    When we start the Spyders, without touching any buttons other than the starting of the Spyder, the gauge will always read different from the last time we started the Spyders and we have to manually press the mode button to whatever we want it to read which is the time. We know how to change it...we just wondered if there was some way for it to stay on i.e., TIME or whatever without it always on something different each time you start the Spyder.
    Quote Originally Posted by Bonniele View Post
    It sounds like time to take it to the dealer. If the gauges are changing without any input from the mode buttons--something does not appear to be right. I would look for a stuck button first--(per Scotty). Maybe even manually cycle through some modes to make sure all is well or not. Dealer is last resort--but may be required here.
    Adams, TN
    My 2012 Spyder RSS does the same thing. Do you really think it is something that should go to the dealer?
    Very Active Member mike3069's Avatar
    May 2008
    Saratoga Springs, NY
    Quote Originally Posted by JXVolker View Post
    No.
    The left handle bar button that you use to reset the scrolling screen display before you can start the spyder, is also a "mode" button. When you press it to reset the screen it also will change the display. I don't know any way around this.
    Just keep pressing that same button untill you get what you want on the disply, then start your spyder. You can use this button at any time to change the display (and it doesn't get stuck like the one on the dash).
    The glass is half full.
    Mike Murphy
    Happy Spyder Owner
    Invalid Emails
    Feb 2013
    California
    Default Thank you...I had forgotten about the mode button to start the Spyders.
    Quote Originally Posted by mike3069 View Post
    No.
    THANK you so much. I had forgotten that mode button. Will see if this makes a difference. Of course, I never think to look at the gauges until after I have started the Spyder. This is probably something that was changed after the 2012 Spyders were built.
    Active Member 1VENOM's Avatar
    Oct 2009
    Virginia Beach, VA
    Yep, sounds like your holding or re-tapping the mode button or the button on the left handle bar. Done it myself.
    Catching a Yellow Jacket in your helmet at 65 mph can double your vocabulary
