back glo ryder lights....help please
Help please.....i just bought a set of second generation glo ryders for my 2012 rt spyder.i havent gotten them yet but i forgot about the back wheel....do they make one for the back wheel since its not the same as the front. If anyone knows what kind of glo light i can put in there please let me know....also u have direct links please share..
Thanks
Chuck
Try getting in touch with "Kratos"...
He's done a ton of research on this topic, and can probably point you in the right direction!
lights
...who is that.??? does he have a link to his web page or how do i contact him?? Im kinda new at this website..
Chuck
short answer is no
Gloryder does not offer a light for the rear wheel of the Spyder. You can mount LED strips to enlighten the area, or do as Bob suggested & send a PM to Kratos for his suggestions
Man thats wierd that glo ryders would make lights for the front and not for the rear.well ill try to figure out how to pm kratos and ask him.
Thanks
Chuck
PM to Kratos
Go to Forums, click on Community then members. Go to "K" and go down to Kratos. Clicknon Kratos then on Send Personal Message (P M). Type the request the Send
Thanks
Chuck
It is really not weird at all. In the first place the rear has no exposed hubs to mount them on...the axle passes straight through and is capped. In the second place, the rear axle location is pretty well obstructed, by the muffler on one side and the belt guard on the other. Look at some underbody lights from TricLED or Custom Dynamics as an alternative.
Kratos' setup is nice, but is far from plug and play. Took a lot of work. It is also hindered further by the fact RawDesign no longer makes the power pucks for the spyder. Your best bet is to install some lights on the underside of the swingarm.
