Results 1 to 13 of 13
    GOS member (Girls On Spyders) ruthie's Avatar
    Feb 2011
    Collinsville, Mississippi
    Default Need your help now! oil chg ???
    Doing our first at home oil change. What is the little filter for that is next to the oil tank? Do you change it with each oil change? Thank you in advance
    2014 RT SE6 Limited
    rYding Safe = Having Fun
    Ruthie
    Registered Users Mad Mike's Avatar
    Mar 2013
    Owenton, KY
    If you have the SE5 trans., You have a transmission oil filter and the normal oil filter. I'm no expert but I would change both. Then again, My dealer does it..
    2011 RT LTD w/XM. And a heavily modified and happy owner.
    Default Depending..!!
    yes you change filter/filters with each oil change. Depending on if you have the semi-automatic which has two filters. One for the engine and one for the transmission. Also change the O-rings and the crush washers (those little copper washers on the drain bolts). Check owners manual...opinions differ but for my way if thinking these parts are cheap and save on oil leaks and costly internal problems....may it go smoothly...
    ​2012 RS sm5
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Lightbulb
    DO NOT mix the trans filter bolts with the engine oil filter bolts. They are different lengths. Do not over torque them. They seal well if installed correctly and there's no need to tighten them tell they squeak. Use a torque wrench where you can and follow torques specs.
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by ruthie View Post
    May I suggest you get the shop manual for your Spyder and use that info to change your oil properly. There is a 3 page procedure in the shop manual for changing the oil. The second time will be easy...
    JT
    Feb 2011
    My Snyder is ready for Maggie Valley (Owner's event) and Dillard, GA (Gold Wing event). New engine filter, HCM filter, oil changed all done. Polish and shine Soyder the day before we leave. Thanks to all the folks that answer the questions I had.
    2014 RT SE6 Limited
    Ruthie
    Invalid Emails
    Sep 2012
    Clermont Florida
    Great job Ruthie ride safe and have a great time at the rally wish i could have gone, hope someone shoots a vidio would love to see all the folks having a great time while im confined at home aft surgery.
    Mike
    Invalid Emails
    May 2012
    Wilkes-Barre PA
    Default shop manual
    Quote Originally Posted by jthornton View Post
    JT
    Where did you get the shop manual from? Thank you for any info you can give me.
    Feb 2011
    We ordered the book from www.midwestmanuals.com we did a download to our computer. It is a very big book so. Oh Lamont's has a video of doing an oil change without taking everything off like the manual said. Not bad doing that way, do have to work getting into some places.
    2014 RT SE6 Limited
    Ruthie
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by arris View Post
    There are several places online and all are based on green manuals. Some have more info than other.
    JT
    Nov 2012
    North Las Vegas, NV
    I just did my first oil change at home. Got the manual on ebay in CD form odd thing is on the three page oil change part it does not tell you how tight to get the oil filter bolts but it does have the torque for the drain plugs.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2008
    Allegan, MI
    Torques for the fasteners are usually listed on the blow-ups at the beginning of each section.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Mar 2011
    PA
    Default Warranty
    I just traded in my 08 for an 2013 RT, If you do the service maint. at home without the dealership rip off. Doesnt that void the warranty?
