Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    May 2013
    Battle Ground Washington
    Default Windshield cleaner
    Good Morning everyone,
    is there some special cleaner I need to use or should I just use some Iso Alcohol? Any helpful ideas is appreciated.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I use a an automotive glass cleaner that is safe for Lexan & window tinting film. Cannot use ammonia based cleaners windex. I use a clean microfiber cloth to wipe the windshield
    Mar 2008
    Allegan, MI
    I wouldn't use any product with alcohol or ammonia. Plain water is probably the best. Some people use hydrogen peroxide for the buggs. I use Windex Multipurpose with Vinegar successfully on all my windshields. Some swear by Pledge or similar products, but they leave a sheen for me that causes raibows when viewed with polarized glasses. Non-abrasive products made for plastics or aircraft windshields, such as Plexus, work well. I like the one Cee Bailey markets.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Same Windex used here!
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Microfine cloth and Honda polish... keeps your windshield clean and scratch free!
    JT
    Active Member KAPike's Avatar
    Aug 2012
    Bridgman, Michigan
    I keep a micro fiber cloth and a spray can of Plexus Plastic Cleaner in the rear cargo trunk all the time, Quick wipe after each ride keeps the windshield and the entire front end nice and clean.
    Kraig
    2012 RT SE5
    2010 RT-622 trailer
    2013 Triump Bonneville T100
    1971 Honda CT70
    1972 Honda CT70H
    Feb 2013
    Morris,mn.
    Default Cleaning windshields
    Windex or half hydrogen peroxide and water works great.
    Jan 2013
    San Diego area
    Default clean windshield
    I use the half water half hydrogen peroxide for bugs and just soap and water when I clean the whole machine.
    Active Member Hokiev's Avatar
    Jun 2011
    Indian Land, SC (30 miles S of Charlotte, NC) was Spotsylvania, VA
    I use Honda Spray Polish on everything on the Spyder including windshield. Similar to Plexis and cheaper.
    HokieV
    2015 RTS Intense Red Pearl (New Jan. 2016) - Comfort Heated Seat w/Backrest, Custom Dynamics HMT Brake Light, superbrightled.com Brake Light Strobe, TricLED fender lights w/Blinker Module & Turn Signal Strips, Stebel Nautilus Horn, FOBO TPMS, Spydercuff, Dual USB outlet, Bike Barn.
    Previous - 2011 RT Limited.
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    I use both Plexus and Honda Cleaner & Polish.
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
    May 2013
    SW MO
    Default Cleaning Windshields: No Windex, No Ammonia, No Paper Towels
    "Do not clean acrylic or polycarbonate screens with common glass cleaners. The solvent action of the alcohol or ammonia will destroy the plastic." National Cycle http://www.nationalcycle.com/WhyBuy/chapter6.html
    "Never clean a motorcycle windshield with traditional glass cleaner. Products containing ammonia or alcohol will damage Plexiglas windshields on contact. Do not use paper products, such as paper towels, on a motorcycle windshield. Paper products contain wood fibers that will create fine scratches on the surface of the windshield." How to Clean a Plexiglas Windshield on a Motorcycle | eHow http://www.ehow.com/how_4811857_clea...#ixzz2UWCC2vn8
    "Have you ever noticed those windshields that look as if something is scratching or flaking off on them? Chances are, you're looking at a windshield that's been cleaned with an ammonia-based product like Windex. Ammonia-based cleaners and Lexan windshields do not go together. Windex is meant to be used on glass and glass only." http://www.thunderingeaglemotorsports.com/MotorcycleWindshieldCare.php
    "...avoid glass-cleansing agents such as Windex, or petroleum-based chemicals such as Rain-X and Armor All -- the solvent action of the alcohol in these products can be harmful to some shields." http://www.motorcyclecruiser.com/tech/windshield_care_cleaning/#ixzz2UWE351Cs
    "Do not use Lock tite, ammonia, bleach, Windex, Rain X, or any other type of kitchen cleaning products." http://www.ceebaileys.com/cycle/windshieldcare.html
    "The original equipment Honda Gold Wing GL1500 and GL1800 windshield is made of hard coated polycarbonate. Most other manufacturers shields are the same. While polycarbonate is great stuff, if you use cleaner containing alcohol or ammonia (including Windex® or Pledge®), you start softening the hard coating , exposing the windshield to greater tendency to scratches or pitting. Windex, Pledge and other alcohol-based household cleaners work great on glass, but aren't meant for synthetics. WARNING: Do not use Rain-X® on any coated windshield!" http://www.allamericanprod.com/hints.html
    I have been waiting to try the hyrodgen peroxide. Now that the bugs are out--I am going to give that a try.
    Active Member rojodawg's Avatar
    Feb 2013
    The Woodlands, Tx
    I use Detailer's Pro Plex-All and a microfiber towel. It's about half the price of Plexus and performs just as well IMHO. It comes out of the can as a light foam, so you get good coverage with a small amount. A 19 oz can will cost you $10-13, but will last a LONG time.
    Linden, CA
    Default Don't forget ....
    Good ole soap and water with a soft cloth works just fine and is almost free
    Feb 2013
    Poplar Bluff, MO
    Too bad it doesn't come in a spray can that won't leak in the trunk... I have a hard time finding rinse water and my shammy when I'm on the road. Honda Cleaner not only cleans every surface, it protects the finish but it ain't free.
    JT
    Invalid Emails
    Dec 2010
    Augusta Georgia
    Place a wet microfiber cloth on the windshield if it has lots of hard bug residue and let it sit for ten min or so then wipe off. Works great. When wiping dont use too much pressure as the bug exoskeleton is very hard and abrasive.
    Very Active Member TexasSpyder's Avatar
    Apr 2012
    USA Andrews, TX
    I carry an old windex bottle filled with RO water with a teaspoon of dishwashing liquid mixed in and microfibre cloths. At each fuel stop if needed I give it a shot and wipe the bugs and dirt off.
    J. D.
    2016 F3T Magnesium Metalic : Smooth Spyder Dual Backrest, Lamonster LED Head lights and Fog lights
    Active Member Farmbanker's Avatar
    Sep 2012
    Alburnett, Iowa
    Default Re: Windshield cleaner
    The Wizards Mist n Shine works great as well and is pretty inexpensive. It is for plastic. I carry a small bottle with me all the time...
    Sent from my SCH-R530U using Tapatalk 4 Beta
    Red 2016 RTS, Diamond R Armrests, Ram X Mount, Doc Humphreys Dampener, BajaRon Swaybar, Spyderpops "Critter Splitter"
    "It is the common fate of the indolent to see their rights become a prey to the active. The condition upon which God hath given liberty to man is eternal vigilance; which condition if he break, servitude is at once the consequence of his crime and the punishment of his guilt." John Philpot Curran 1790
    Nov 2012
    North Las Vegas, NV
    A wet (saturated) towel works great. Just leave it on there a few minutes viola bugs gone.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member cpdblegl's Avatar
    Dec 2012
    Burien (B-TWN), Washington
    When the shield is covered with bugs, I always leave a well soaked towel draped over it over night... followed in the morning by Pleaxus cleaner for a wonderfully clean surface to see through.
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    I use a gallon regular blue auto windshield cleaner for 32+ degree and a gallon yellow auto windshield cleaner for bugs. Then I mix them 50/50 and use a spray bottle and soft windshield cleaning rag. I spray on the mix and let it for sit for a few minutes and bugs comes off without rubbing hard. I got this mix from a motorcycle windshield manufacture That's IMHO.
    Mike
    Mar 2008
    Allegan, MI
    Quote Originally Posted by MikeinGA View Post
    Mike
    That sounds interesting. I think I'll try it.
    -Scotty
    Invalid Emails
    May 2009
    Clearwater Florida and Frankin NC
    Quote Originally Posted by cpdblegl View Post
    Same way I have always done it. No scratches and a nice clear shield.
    Member Dliles6254's Avatar
    May 2013
    Blue Springs
    Default Go with the Honda cleaner
    Quote Originally Posted by jthornton View Post
    JT
    I use the Honda cleaner as well, it works well on the windshield, really it works good on every part of the spyder
    Feb 2013
    Poplar Bluff, MO
    Quote Originally Posted by Dliles6254 View Post
    Yep, I use it on everything except rubber and leather (seat, tires, grips).
    JT
