There is no gasket used !!!
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Catching a Yellow Jacket in your helmet at 65 mph can double your vocabulary
removal
how do you get rid of the one thats on the bike side of the exhaust?
Really..!!
When I installed mine I just pulled off the OEM slid on the Hindle clamped down hooked up the one spring and done...the gaskets are at the heads and Y joint..
2012 RS sm5
Check out this thread....it also has a link to you tube http://www.spyderlovers.com/forums/s...hindle+install
HAPPY SPYDER OWNER
GULF COAST SPYDERRYDERS
I don't have a Hindle, (mine's a Two Brothers Racing unit).................my TBR slip on did not use a gasket like the stock S pipe did. The stock gasket came out stuck inside the stock S pipe; sounds like yours stuck to the outside of the collector pipe. Just pull it off. My TBR slip on came with some high temp RTV silicone sealer, to run a bead around the inside of the S pipe mouth; that didn't seal the joint completely for me, so I ran my Spyder up on some low profile car ramps to access the underside of my Spyder more easily. I used my finger tip to run force the high temp RTV into the S pipe/collector pipe seam; then used a shop rag to wipe off any excess RTV. Sealed mine up fine. Good luck! BTW: Ultra high temp RTV would probably be more appropriate for this type of application.........................just sayin'.
2018 F3 S, BRP SS Grill, Spoiler, Attitude Bars, #1 linkage kit, Chopped R Fender, TBR S1R slip On exhaust, Elka Stage 2 R Shock, Shad saddlebags
hindle exhaust install?
Not to long ago I posted up the summit racing part number for the band clamp we used. Works great and seals perfect with no glues needed.
