These videos really helped me to visualize the frunk removal and sway bar installation. Once I had watched them, the installation was easy. Thanks for the post!
This video will show you how to remove the front trunk on a GS/RS.
This video will show you how to install the BajaRon Anti sway bar on a GS/RS. Watch trunk removal video prior to viewing this.
Thanks, this was VERY helpful, the only thing that I would add is that if you are going to replace the links, you would be well advised to remove the 2 "panels" that are over the top of the links. #8mm screws use a drill/driver. Makes life easier.
I used both of those videos when I installed my sway bar. Most helpful. And I saved them to post whenever anyone asks about doing so. I spent way too much time trying to find them on here when people would ask; simpler to just save them.
I still do not understand why these are not a 'sticky' for future reference.
Thank You so much,
Jerry Baumchen
PS) You and finless (Bob) deserve some type of award for all of the work you have done in making a number of videos.
