Results 1 to 10 of 10
Thread: HANDLEBAR GRIPS
    Registered Users eagle's Avatar
    Dec 2010
    benson,mn.
    Default HANDLEBAR GRIPS
    I have read some threads about putting a wrap-around grip cover, that is held together with velcro, over the present grips on the spyder. Where can these be found?
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Default Covers
    They are not sight sponsor. But are beleave they are called grip buddies.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Big Rig Member diesel-dawg's Avatar
    Apr 2013
    Calabash, North Carolina
    Quote Originally Posted by eagle View Post
    TRICLED.COM has the grips that fit right over stock grips. Easy to install. Check them out. I ordered online and had them on the bike within a week. I bought 2 pair, one to apply to the bike and one later after they wear out. Good prices also.
    Invalid Emails
    Oct 2010
    Portland, Oregon
    The ones that my wife and I use on our Spyders come from www.hotleathers.com/
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    I learned to play tennis at an early age. (7) I love the feel of the grip on a tennis racket. Consequently, I went to Sports Authority (or you could go to Dicks) and bought the leather wrap for a tennis racket. It works well and absorbs a helluva lot of the shock much as the racket receives.
    Chris
    The ones you refer to are grip buddies. They were, but are no longer a site sponser. I had a set on both 's. Akspyderlady likes them, I don't. The block the heat on the handgrips for me.
    PM me if your interested. I will cut you a good deal on my unused ones.
    GOS member (Girls On Spyders)
    Feb 2011
    bay city, michigan
    you are indeed referring to "grip buddies" work great, and if you have heated grips....can still feel the heat.
    http://www.originalbeemerbuddies.com/
    Apr 2012
    Columbus, Ohio
    Down side to the grip buddies is that you can still feel the seam where you join the ends together. That
    part I didn't like, so I switched to the ones that Tricled sells. Much better. Just an FYI.
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    I have fitted ones called Grip Puppies - These slide over the original grips so there is no joint to catch or come undone - Very easy to slide on - Can still feel the heated grips through them
    See - http://www.casporttouring.com/cst/mo...s/GRIPPUP.html
    I have had a pair on for over a year with no problems and no noticeable wear with them
    See Pictures of them installed on my Spyder RT -S SE5 2010 Model
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Very Active Member sealfloorboards's Avatar
    Aug 2010
    Newberg, Or.
    My Grip Buddies have worn out in less than a year. They also tend to slide around. Will go to Tricled for new ones.
    Ride in comfort,
    John
    Seal Floorboards
