4 way flashers stop working
Hey I have a 2011 Rt the 4 way flashers stop anybody can help me tell me what is wrong or to check
Are your brake lights working? They are on the same fuse (on 2013 anyway). Are you getting any error codes?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
4 ways
brake lights work no code
Check..!!
to make sure all lights are working, turn signals, brake lights, running lights then see if they flash when in reverse. If all that is working must be the switch..if they come on but don't flash you need to check the flasher unit... Let us know what you find....
Good idea to see if they work in reverse. There is no flasher unit it is controlled by the instrument cluster.
2018 F3 LIMITED
RT flashers don't flash in reverse like the RS.
Check my post on the Reverse switch...The hazard switch is the same way...give it a couple of short blasts of WD-40 and let it soak in. That may do the trick...
Where I've been on my Spyder...
