ordering the bumpskid
Originally Posted by diesel-dawg
thanks guys for the input....very informative. Needless to say, I am ordering the bumpskid.
Hi,
May I ask where you are purchasing the bumpskid? I look at the vendors on the site and unless I missed it, do not see anyone who sells them. Thanks Ron
Big Rig Member
Originally Posted by zbunker
Hi,
spyderpops.com is the place. They had it in shipment almost immediately after placing the order.
Bumpskid....is it needed?
What about aquaplaning?? I am afraid this big flat plastic piece will act as a surf board on any puddle!
I'd love to have a metal plate under the engine.
I haven't had any surfboarding. The frame is under the engine. Don't think metal will do anything for you other than add excess weight.
If your driving at speed in 6" of water you will have other things to worry about instead of hanging 10.
JT
Motorbike Professor
JT
Amen, brother, amen!
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Did anyone in Spyderfest take a picture of the OEM plates that Spyderpop removed before installing the Bumpskid Plate? Some of them made me wonder how the still had a front end!
May all your encounters with the law begin with the words: "nice trike!".[/B]
2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
Previously owned:
2010 Can-Am Spyder RT SM-5
2011 Can-Am Spyder RS-S SM-5
2013 Can-Am Spyder RT-S SM-5
Yes I have one and it save my Spyder's front end. You will love the plate
2012 Spyder RT-SE5 Gray 5-31-12 First 5,075 miles on 10-8-12
NBV kit highway brackets with pegs Bajaron sway bar Lave exh wrap
Grip Buddies AirHawk 2 His & Her's Walmart Front driving lights
Spyderpops upper block off plate, belt guard, bump Skid
BRP trailer hitch Napa 6 to 4 wire power converter Ram GPS upper dash
Baker build air wings the New 3 piece full set Kewl Metal GPS hand bar
Inspector Gadgets rear mudd flap type, Air deflectors upper & lower A-frame
Big Rig Member
got my bumpskid delivered today. spyderpops.com surely is on top of his game. Great service on this order.
bumpskid
I wasn't sure if it was needed but bought one and when I installed it and when I saw the condition of the factory skidplate realized that it was a very good and wise investment.
It was the first mod I put on the bike.
I have used it, it works, and I would do it all over again,... and it looks great to boot!
The thing is, the skid can be replaced if it gets damaged too badly, the nose of your bike is a little different.
SpyderLovers Sponsor
Saves the frank
I hit one of those highway alligators with mine. I'm sure I would have had a lot of damage without it. It helped my rt slide over the tire chunk and keep control.
Saves the frunk
Works better than auto correct
Is it worth it?
I had one put on spyder fest last year, well on the way home foggy rainy didn't see a dead armadillo when thump crunch we ran it over , bump skid paid for itself in 5 miles after spyder fest 2012. Saved the frunk ! It's worth every penny!
Gary
Well i think you get the picture here................ Get a Bumpskid.
Cruzr Joe
Originally Posted by SilverSurfer
Within one week, I improved handling and mpg on my RT:
Bump-Skid (critter splitter) - In addition to protecting the front underside of the nose, the unit seals a big cavity from the front to the rear of the front, stopping just in front of the suspension, a space subject to air drag under the Spyder. Gone. Less 'sail' from the faring. It also amplifies some down pressure on the front of the Spyder when at highway speed ... stability. Better aerodynamics = better mpg.
BajaRon's Sway Bar. Installed along with Bump-Skid. Combine this with my front Elkas Shocks ... The Spyder is on rails.
BRP Can/Am Spyder Sport Touring Vented Windscreen - reduced windsreen profile by 2" vertically and 3" horizontally. Less wind resistance and less buffeting. Helps highway mpg
Regarding mpg, the Spyder is always (and affectionately) a gas junkie when moving around streets and neighborhoods. The combination of the bumpskid and sport touring vented windscreen have my highway mpg up to 34/35 mpg solidly, riding one-up at 199 pounds without cargo. Mpg on the Spyder is strongly affected by passenger weight, two-up/one-up, trailer/cargo weight and other variables. The aerodynamic, and modest fuel economy improvements offered by the Bump-Skid and windscreen modifications, in my opinion, are most optimal at highway speeds (50 mph and over). Otherwise, the greatest influence on Spyder mpg is rider/passenger weight and cargo.
I've put most every mod I could and I've been resistant on the bumpskid because with the Elkas and shock relo kit I'm sitting pretty high. This is the first post I've seen espousing aerodynamic benefits. I noticed you put the sway bar on at same time. Do you think that had more to do with handling improvements?? I've got everything else you have including sway bar and sport windscreen. You definitely have me reconsidering this, thx
Big Rig Member
I just completed the install of the bumpskid on my new RT LTD. Great piece of work by Spyderpops.com ... The screws sent for the installation work fine for the front, but were too short for the rear installation, as you need some grip to be able to mold it a little. I went and bought 4 each #6 metric screws, somewhat longer than was included by Spyderpops. Other than the screws, it was to my liking; I think it will do the job! To avoid damaging the edge of the skid, it seems like a hardened rubber rim would be an additional thing that should be designed into the bumpskid.
Me lika me bumpskid!
Nothing was cheap at SpyderFest. :P But had to get the BumpSkid from Pops. I was a wus and trailered my bike up/back from TX.
I had it strapped down on the open trailer. On the way back, I noticed in the mirror that the front straps were 'slack'! I pulled over and sure enough, the rear strap had broken and the bike had moved forward, going into the front rail/wall. Needless to say, there's a small ding/notch in the BS now BUT no crack or damage to the front plastic or frunk!
Was obviously worth the $. Have been busy since being back so haven't ridden enough to warrant comment on performance of it, but it surely can't hurt!
J / Roof Man
Motorbike Professor
J / Roof Man
Having towed more bikes than I can count, over more miles than I can count, I can only say one thing...
"Double up on the tie-down straps...always!"
Straps break, move, or can snap in a collision. Two sets of straps is much cheaper than repairing your ride. I learned that the hard way, a long time ago.
-Scotty
Great Investment.
I installed the Bumpskid today, I was surprised how much the bottom was scapped in only 800 miles. It was an easy installation.
I did remove the ribs along the edges so the plate fits better.
it looks good and I think it will improve fuel mileage. On just a short test after installation it feel solid in the front.
Is it necessary to lift the front end to install the bumpskid?
David Horn, Kerrville, TX
Fulltime RVer
2014 Phaeton 40ft motorhome w/TandemTow trailer
2014 Mazda CX5 (Soul Red)
Ringo, the travelin' canine (just black and tan)
Big Rig Member
Yes, it was necessary for me, since the front end is so low. I went to Harbor Freight and bought a set of their metal tire ramps for about $40. Simply drive each front tire up on them and set the parking brake. Ready to install the bumpskid...
