Results 1 to 12 of 12
    Registered Users Pablito's Avatar
    Apr 2013
    Oviedo, FL
    Default Ram Phone/Phablet mount on RS
    Hey y'all here is my most recent DIY project. I wanted to be able to mount my Samsung Galaxy Note II and/or mount a regular GPS. I wanted it high enough to not have to take my eyes off the road when looking at it to find my way yet not really in the way either. Here is my solution. I ordered parts from Ram Mount and a large phone/phablet x mount. I drilled a 13/64" hole in the top of the handle bar cover then tapped it for threads and installed a a ball mount with a stainless steel allen head screw and washer will probably Plasti dip the screw and washer black to match but thats not a biggie as for now i have my phone/gps mounted and works great. *note* it does cover up part of the speedo dial however i never look at that one anyway and only watch the digital speedo.. besides, do we really need 2 speedos????
    20130424_142407_resized.jpgHole drilled
    20130424_142559_resized.jpgTapping the hole for threads
    20130424_142639_resized.jpgThreads
    20130424_142734_resized.jpgStainless Steel Allen head screw from Home Depot
    20130424_143019_resized.jpgBall mount is on and secure
    Apr 2013
    Oviedo, FL
    Active Member NoJive's Avatar
    Jun 2012
    Beckley, WV
    Nice! I have a Note 2 and was looking at mounting options. How well does the RAM mount hold it?
    Jive
    Beckley, WV
    2012 Pure Magnesium Metallic Spyder RTS SM5, SpyderPops Belt Guard
    Registered Users Dwanton's Avatar
    Apr 2012
    Southern jersey
    I installed a 1'' ram mount on my RSS for the note2 and love it --- holds great and use my bluetooth headset -- now I can see whos calling , use GPS and use pandora .
    got all the stuff I neededd from GPSZONE.com
    2012 RSS orange / black SE5 , Sport rack , backrest , comfort seat , console protector , front trunk liner , yoshimura R-77 carbon fiber , two brothers juice box pro using PC map 6 , K&N air filter , factory fog lamps
    Jun 2012
    Beckley, WV
    Thanks for the pics. I think that is what I will end up getting, as I have read a lot of good reviews.
    Jive
    Beckley, WV
    Active Member Grandpa Pete's Avatar
    Sep 2012
    Rockford, Minnesota
    I've got an LG Intuition and was looking for this kind of mount. Thx for the pics..Gives me some good ideas
    Grandpa Pete
    Peter & Kim Pontinen
    2020 RTL Dark Marsala
    Active Member mclaw44's Avatar
    Aug 2009
    Ohio
    Just got the same ram mount for my iPhone, installed on my Spyder last night and love it rode today and it was perfect.
    Open up your Mind and let your Fantasies Unwind!
    Jan 2013
    Tampa, Fl
    Quote Originally Posted by Pablito View Post
    Indeed, I did the same thing, it looks great. It doesn't block your view. The phone my droid bionic with an otterbox holds on perfectly and leaves room for the charger!
    Apr 2013
    Oviedo, FL
    The Ram X-Mount holds it terrific. I heard they were good but didnt really know just how strong they would really be and wow I'm impressed and very happy i took others advice and went with this one... Best mount on the market IMO
    May 2012
    Pearland (near Houston), TX, USA
    I have the original International Note and the same Ram Mount on a windshield mount. It is pretty sturdy but I just did not trust it to hold a $600 phone with nothing more than spring pressure. Hopefully I'm just too paranoid and it will work fine for you.
    By the way, I used this http://www.rammount.com/Gallery/imag...RAM-B-346U.jpg to put a ball mount on the Spyder.
    David
    arntufun
    Guest
    I'm not looking to highjack the thread only to offer another option.
    Another way to mount a ram ball is to remove the black plastic filler piece on the throttle side located between the throttle and handlebar cover. This is easy to remove by taking the throttle off sliding this filler peice off and reinstalling the throttle.
    This will give you enough space to install a 7/8 handlebar ram ball mount. Also you will have no permanent damage to your Spyder.
    Mar 2012
    NJ
    I don't think there is any hijacking going on. These are all fantastic ideas to mount some essentials to the spyder. It's all about doing what works and putting our own little spin on things to make it work best for us.
    I did all of my mounts for my GPS and phone over the "vents".
    http://www.spyderlovers.com/forums/s...-Iphone-Mounts
