Thanks Thanks:  1
Likes Likes:  0
Results 1 to 5 of 5
    Big Rig Member diesel-dawg's Avatar
    Apr 2013
    Calabash, North Carolina
    Default 2013 RT Limited front shock adjustment
    I called my dealer this morning and asked how to make the adjustment on the front shock to a 5, to make it stiffer. He checked and said evidently the 2013 does not have an adjustment that can be made. Do any of you know if that is part of the suspension upgrade for the 2013? thanks
    Teddys favorite human CyncySpyder's Avatar
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Exclamation Correct - The 2013 Model RT's do not have any adjustments built in
    Its not like the previous models where you had a 1 thru 5 scale of stiffness to choose from, its one setting fits all for the new suspension
    Jun 2010
    Post Here's the 2013 parts schematic just for clarification
    Apr 2013
    Great...so as I understand it, you can't do anything to stiffen the front, other than what comes from the factory and the electronic load adjustment switch only adjusts the rear end suspension....is that a correct understanding?
    SpyderLovers Sponsor bullant12's Avatar
    Oct 2010
    Somewhere out there...
    Quote Originally Posted by diesel-dawg View Post
    Correct... the rear controls how hard or soft you want your rear to respond. This is necessary to contol based on 1 or 2 up and/or trailer pulling. I guess because of the new re-positioning of the shocks on the '13, BRP did not add a front shock adjustment.
    May all your encounters with the law begin with the words: "nice trike!".
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
