Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Nov 2012
    Jacksonville
    Default USB in rocker switch slot
    Having only a RT A/C I have 2 open rocker switches on the dash. Has anyone engineered putting a USB outlet (preferrrably whether proof) in the empty rocker switch slot?
    Invalid Emails
    Dec 2007
    winnipeg mb
    Here's a thread posted just the other day should give you some ideas:
    http://www.spyderlovers.com/forums/s...ole-(Version-2)
    Very Active Member bullant12's Avatar
    Oct 2010
    Somewhere out there...
    Quote Originally Posted by spyryder View Post
    Thanks for reposting this!
    Quote Originally Posted by Wazoo View Post
    Here is the part: http://www.burnsmoto.com/waterproof-...anel-mount.php You might need to make the cable longer since they only sell it at 4 feet.
    May all your encounters with the law begin with the words: "nice trike!".[/B]
    2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
    Previously owned:
    2010 Can-Am Spyder RT SM-5
    2011 Can-Am Spyder RS-S SM-5
    2013 Can-Am Spyder RT-S SM-5
    Jul 2014
    Washington DC
    Wazoo, I was wondering if you were able to find a rectangled weather proofed usb switch for the rocker slot? @Bullant12 idea was brilliant but the previous owner had the CB kit inatalled and the circle in use, so I need to use the free bays on the right.
    Active Member Moosemanj's Avatar
    Pensacola FL
    Just bought the dual usb port for my RT from Lamonster's Garage. Just have to install it now.
    Active Member The Governor's Avatar
    Sep 2014
    Argyle, Texas
    I did this....
    1. Check fluids & tire pressures.
    2. Start bike.
    3. Hold on.
    4. Full throttle.
    5. Repeat 3-5.
    Jul 2014
    Washington DC
    Quote Originally Posted by The Governor View Post
    I did this....
    That's a pretty cool location to have it, but I have a cellphone holder that will not work for me as the cable will go outside and may bend the rubber seal.
    Jul 2014
    Washington DC
    Quote Originally Posted by Moosemanj View Post
    Did you buy the spyder dock or does he has a usb port that would fit the switch bay?
    http://www.lamonstergarage.com/lamon...h-12v-cig-usb/
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    The one that goes in the rocker switch location are only weather proof when not in use. The USB+12v I have comes with a weather proof in use cover for one cable.
    JT
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    I was going to do this but a few posts said I might screw up the rubber seal, wasn't sure that was a big deal , what have you experienced ? How tough was it to get the nut tightened on the power plug ? Where did you hook the wire to ? direct battery ? Any info you could give me will be helpful .....thanks for your post
    Quote Originally Posted by GeekyRider View Post
    2016 RT-S , white
    Very Active Member JimVonBaden's Avatar
    Oct 2016
    NoVA
    Quote Originally Posted by jthornton View Post
    JT
    Technically true, but I have used mine in the rain lots of times. Low voltage doesn't conduct in water very well.
    Amazon $12.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jim
    2013 ST-S (wife's)
    2015 BMW R1200GS (mine)
    1981 Yamaha XS400 Scrambler Custom (mine)
    Idaho
    Quote Originally Posted by JimVonBaden View Post
    Technically true, but I have used mine in the rain lots of times. Low voltage doesn't conduct in water very well..
    That's not the concern. Corrosion of those tiny contacts is.
    Sent from my SM-T350 using Tapatalk
    2014 Copper RTS
    May 2013
    Stanton, ca
    In my opinion this is the best way.
    It matches the switches in the center, has a rubber plug when not in use, etc....
    This post shows it on the right but with some plastic trimming you can put it in the middle perfectly and it looks factory!
    http://www.spyderlovers.com/forums/s...Switch-Cluster
    Bob
    2011 RT-S SM5 - Black
    Oct 2016
    NoVA
    Possibly​, but a little dielectric grease fixes that.
    Jim
    2013 ST-S (wife's)
    Sep 2016
    Parma, Idaho
    Default Empty Rocker Switch Slot
    Check out JT's Spyder Store for a product called, Carchet Car 3.1. It's a dual USB power outlet that fits in the center empty rocker switch slot. Looks like original equipment manufacture when installed. Has blue illumination, making it visible at night.
    Oct 2016
    NoVA
    Quote Originally Posted by WilderThomas View Post
    Same as I posted above from Amazon for $6 cheaper.
    Jim
    2013 ST-S (wife's)
    Blazing Member fastfraser's Avatar
    Feb 2009
    Orangeville, Canada
    Happy Owner
    May 2013
    Stanton, ca
    Quote Originally Posted by fastfraser View Post
    That's cool! Where did you get that please?
    Bob
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Default This is what you want
    This is the exact part you need for what you describe. It is made by the same manufacturer as the switches and will fit those slots without any cutting. Enjoy!
    http://www.panbo.com/assets_c/2014/1...nbo-10197.html
    2020 RT Limited , Marsala Red
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    2015 RT Limited Intense Red Pearl
    Sep 2016
    Parma, Idaho
    Default USB Rocker Switch
    There's a company called JT's Spyder Store. They have a dual USB "switch" called the Carchet Car 3.1. It fit's neatly in one of those unused rocker switch slots. It looks like an original equipment manufacture, has a weather proof cap, and has blue illumination that is visible in low light. Check them out one day. I've enclosed a link here, but don't know if it can be accessed.
    Sep 2016
    Parma, Idaho
    Default USB rocker switch slot
    Try going to JT's Spyder Store.
    Oct 2016
    NoVA
    I added this to my wife's in place of the standard dual USB.
    Jim
    2013 ST-S (wife's)
    Active Member Large1's Avatar
    Dec 2016
    Boise ID
    I have been looking at the dual USB with the Volt meter setting on my desk thinking of putting it in the empty slot but was worrying about it getting wet, After two weeks I went with the in side of the glove box route< I wanted it to be able to charge when i was parked but didn't want it on all the time so I found a Dorman mini rocker (Waterproof) installed it in the empty spot wired to the USB in the glove box alone side of a standard power outlet,
    Now I can turn it on and charge what ever and still be able to see the voltage.
    Seeing I have never had the tupperware off and thanks to BMW and my old K1200LT I had a good idea but still getting to the Glove box is a real Pain
    Dick Harding
    Boise,ID
    2011 Spyder RT SE5 Limited
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
    Large1 is online now Report Post
    Sep 2016
    Parma, Idaho
    Don't know if you've managed to find a solution to your question yet, but you might try JT's Spyder Store. There's a device he sells which fits into that empty rocker switch slot, is weatherproof, looks OEM, is illuminated at night, has the jacks for two USB plugs. It's called a Carchet Car. And I have one installed on my 2012 Can Am Spyder RT-S. Just a thought.
