On my previous I bought a part from Burnsmoto.com which I can connect to my battery (I actually got the SAE connector and hooked it to the Battery Tender's ring terminal harness that was hooked on the battery. When not in in the Tender, I would connect both and the USB cable would be "hot). I wanted to hook up the USB harness where the rocker switches console is, but I could not fit a square peg in a round pole literally. When I went back to the burnsmoto.com website again, I saw a new USB plug that would actually fit on the hole where the wired comm system would go. After a considerate amount of time and getting the console removed (not easy), I got the USB socket installed (had to expand the hole a little more) and it is wired to the battery. I can later wire it to an additional fuse box like Tricled's FZ-1 Fusebox.
Reason: Fixed pictures
May all your encounters with the law begin with the words: "nice trike!".[/B]
2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
[QUOTE=bullant12;608837]On my previous I bought a part from Burnsmoto.com which I can connect to my battery (I actually got the SAE connector and hooked it to the Battery Tender's ring terminal harness that was hooked on the battery. When not in in the Tender, I would connect both and the USB cable would be "hot). I wanted to hook up the USB harness where the rocker switches console is, but I could not fit a square peg in a round pole literally. When I went back to the burnsmoto.com website again, I saw a new USB plug that would actually fit on the hole where the wired comm system would go. After a considerate amount of time and getting the console removed (not easy), I got the USB socket installed (had to expand the hole a little more) and it is wired to the battery. I can later wire it to an additional fuse box like Tricled's FZ-1 Fusebox.
Just don't use the clamp. Make the hole bigger and it will tight in.
I have made adjustments to this mod. Now I installed another dual USB adapter where the gas gauge used to be (I am trying to find pictures... will post them later), and now my phone in on eye level with the dash thanks to JT's dash mount http://gnipsel.com/spyderstore/index...&product_id=50, and power the phone with a coiled power cord.
My next project will involve moving the GPS to eye level with JT's dash, and thanks to Finless, I am going to run an extended harness that can power the iPhone and connect to the sound system.
