Guess What Caused thiis Shifting Malfunction?
This happened to a friends '12 RT SE and these were the symptoms. See if you can guess what caused it. Answer will be provided tomorrow.
The one year old RT SE wouldn't downshift by itself at all. The only way was to manually downshift and when it came to a stop in 1st gear, it idled too low and usually stalled. Either keep a little throttle on it or get it into neutral quickly.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
2018 F3 LIMITED
vacuum hose
Curious..!!
Have an RS so I will wait to see...
2012 RS sm5
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Thinks out loud
1. Low oil level or
2. HCM malfunction - electrical or hydraulic
Best guess - the poor idle condition and the down shift problem are not related. Because manual shift requirement was indicated for downshifting from 5 to 4, 4 to 3, and 3 to 2.
Reason: clarification
Symptoms of a split or broken vacuum line.
Too much air in the front tires?
Oh come on Now I won't be able to sleep tonight This is cruel and unusual punishment
2012 RT Limited: Utopia back rest, SealBoards, and Shark bluetooth communicators on VCAN Woody helmets.
wrong brand of oil?
USAF '69-'89 E7
Thailand/Vietnam 1972
Since mine is doing the exact same thing, I'm saying vacuum lines cracked.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Thinks out loud
Wow!
Bad in a years time. Whoda thunk? Obviously a few did
We in the desert better start changing them annually.
Moral of the story...
"Always carry a roll of duct-tape with you".
It has been known to bring a trio of astronauts home...
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
Anybody know how to change out the vacuum hose?
The more I think about it, the more I want to change mine as a preventive measue but have looked at the Fiche till I'm crosseyed and can't find where its located. I know its somewhere on the left side as thats where the mechanice pulled the panels off. Its a tiny little hose, no bigger than a pencil and although it was in three pieces, I'd say about the length of a ballpoint pen.
Is this a do-it-yourselfer? If so, where the heck is it located?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
....and we're gonna ride, we're gonna ride.....
ride like the one-eyed Jack of Diamonds, with
the devil close behind,.....we're gonna ride....
2008 GS.....PE # 2888
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Sway to go
First off if it was a vacuum hose that went south in less then a year it was sure cheap hose with very poor quality assurance. An I thought GM was buying cheap hose?
Secondly you don't need Honda hose either. Just go to your local automotive parts store and buy a roll of Gates, or Anco, or Trico brand hose. It should be a couple of layers in wall thickness.
When you start running the new lines try to get as far from the heat as possible!
2 Cruysyn: you sent me a link but I can't get it to read. If you will, please resend it.
Thanks
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Thanks
I pulled my post because the more I looked the more I convinced myself I may have been barking up the wrong tree. Here's the illustration and the photo. If you're going to pull the plastic you may as well check all the vacuum lines while you're in there.
If you mess with the MAPS lines the replacements should be the same lengths as the lines you remove. They are 85mm long according to the Service Manual. Also "Tube length is calibrated and should not be tampered with. If otherwise, the engine may be improperly calibrated."
Baja Ron - Dimple - Ultimate - Lamonster Garage - K&N - Smoothspyder - Amsoil - Hiflo - FOBO - Spyderpops
Sena - Dynaplug - Shoei - Tourmaster - Garmin
If you mess with the MAPS lines the replacements should be the same lengths as the lines you remove. They are 85mm long according to the Service Manual. Also " Tube length is calibrated and should not be tampered with. If otherwise, the engine may be improperly calibrated."
No wonder I couldn't find it on my svc CD....thought it would be down around the transmission somewhere.
I've made a copy of the pic and will confirm with the mechanic next time i go to the shop, but it looks like what he replaced. Thanks a lot for the pic.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
Wheres the "other" vacuum line/s?
Pulled the left side plastic and the left side black cover underneath (2 screws) to get at the offending vac line shown in the above picture kindly supplied by 2 Cruysyn . That line is exactly 8.5mm long (about 3 1/2 in) and mine was flexible with no signs of cracking.
Other threads have referred to two or more vac lines but I couldnt find any in that same general area.
Can someone point me to the "other/s" while I still have the plactic off?
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
The other line I would think should be in a similar location on the other (forward) throttle, for lack of a better word. They should both be attached to the MAPS so find the other one and trace it back, or forward in this case.
