Best rear light safety modification
I have installed I think is the best safety modification on my RTS 2012 it is called BackOFF WIG WAG module ,the back lights will flash one side then the other side. you can order it from Signal Dynamics.com. Easy to install. $39 , If someone runs in to me it is because they were on the dam cell phone
Interesting..!!
will check it out..thanks for the info...!!
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Not legal in California.
CVC 25251.5
(c) Any stoplamp or supplemental stoplamp required or permitted by Section 24603 may be equipped so as to flash not more than four times within the first four seconds after actuation by application of the brakes.
Basically, flash four times, then remain solid. I have a CD flasher module connected to my HMT Trunk lid brake light.
2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
