Results 1 to 14 of 14
    Uk
    Default New corbin seat installation
    yesterday I installed my new Corbin seat on my 2012 RT. Two problems the seat latch post would not line up and after reading the forum I removed it.The main problem is that the corbin seat leaves a two or three inch gap underneath the stock passenger trunk/backrest as it does not have the upstand that the BRP seat does. Do I have to order a Corbin backrest to solve the problem or does anyone have some ideas please
    Uk
    Bump
    To get the seat pin to latch you may have to do some adjusting on the back hinge--side to side, front to back etc. The pin also can be adjusted in or out.
    I don't like to mess with stuff like that so removed the seat locking pin and the shock. You can put gas in the bike without raising the seat--so that should not be an issue.
    May 2012
    Greenfield, WI
    You may want to look at the video I put up yesterday in the How to forum. While it is an Ultimate seat that procedure will line up the locking pin for you before you tighten down the hinge positions making the locking pin and gas spring work for you.
    MODS 2013 - Ultimate, Remote / LED Halos, Pete's Dash kits , Elka's!
    2011 RT A&C-SM5 - Orbital Blue (mine)
    Xenon Lights, Polk speakers (4), 5-LED lamps, fog lights, Sypderpops grills, OGB grips, TIPS and CHANNELZ lights. Seal FLRBDS, Two Brothers Muffler, ZUMO 665 w XM, Gloryders, HMT Brake.
    2012 RT-LTD SE5 -Lava (hers)
    MODS: Spyderpops chrome grills, TIPS and CHANNELZ lights, HMT Brake, Seal FLRBDS, Gloryders, OGB Grips
    Feb 2012
    Lake Havasu City,Arizona
    Default Corbin Seat locking ltch post
    Quote Originally Posted by beako View Post
    I had the same issue with my new corbin seat,after adjusting it as much as i could I ground some of the thickness on the corbin latch pin and now it works just fine.
    Jun 2011
    Columbus, Ohio
    I had exactly the same issue this weekend with my new Corbin seat. I removed the pin also. I'm racking my brain to come up with a serious reason why this is a bad idea, but can't think of one. It just seems wrong.
    2014 Spyder RT LTD, 2010 RT-622
    I have over 50,000 miles on the Corbin seats without the locking pin. No one has stolen the from under the seat or my battery.
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    It takes a lot of trial and error.
    Active Member Dizneyman's Avatar
    Sep 2011
    Cocoa Beach, Florida
    I had mine installed by Corbin in Ormand Beach last week and it opens and locks fine. May want to call them and ask about adjustment. Did not seem to take them more than 15 minutes for seat, much longer for arm rests..
    May 2010
    Calgary
    fitted my Corbin 3 years ago to my 2010 RTS and removed the pin. No movement at all when riding. I have the Corbin backrest and there is still a gap between seat and backrest. There are no "filler" panels I know of!
    SteveO
    Active Member gnirtsnod's Avatar
    Nov 2012
    Macon, GA
    I had the same problem a couple of weeks ago and felt foolish when I discovered that the rear hinge bracket on the seat is adjustable for just this reason. Remove the seat and turn it over. There are two bolts holding the hinge bracket to the seat. I had to loosen the bolts and pull the hinge bracket away from the seat as far as possible, then lock down the bolts. After re-installing the seat, I was lined up exactly as it should be. The latch works just fine. There is some additional, minor adjustment where the two hinge sections come together on the bike. You can loosen the hinge bolts and get a little play if fine tuning is necessary.
    As for the void between the seat and the passenger backrest, it won't bother you after everything is installed, and it makes a neat place to store my water bottle while riding. If need be, get an upholstery shop to make a little vinyl curtain to attach to the bottom of the passenger backrest to fill the void, but I doubt if you will notice it past the first week.
    Apr 2013
    California
    Default corbin latch problem
    I have a 2013 with a Corbin seat installed at the factory. Worked fine until I hit a bump and the seat stuck.The Latch pin has two grooves. The bottom groove is where the latch is suppose to hook. But, rider weight can push it passed the top groove and your stuck. Grind off the top ring and smooth the bottom lip on the pin and your fine.
    Or don't worry and toss the pin.
    Double check your seat. There should be a small kick stand to hold seat up and the left side.
    Active Member fencepost's Avatar
    Apr 2010
    Thorn Hill, TN
    I removed the pin on wife's Corbin seat, no reason to have it. I too did not like the space between the passenger back support and the seat so I ordered the same material that seat was made of and had a filler made. It is over size so it just pushes in. I sent another one to Mike at Corbin but he had no interest in it. I think it just completes the package.
    Invalid Emails
    Ormond Beach FL
    Default Do you ever use
    Quote Originally Posted by Cyclist922 View Post
    You may find that you cannot secure your helmets if you remove the locking latch pin.
    Corbin needs to develop better quality control procedures as my Corbin seat has given me problems since day two. Their so called fix is to develop a better fist to bang the latch pin open
    At 72 you don't have a whole lot of fist power left to develop.
