Thanks Thanks:  0
Likes Likes:  0
Results 1 to 7 of 7
    Very Active Member Netminder's Avatar
    Mar 2012
    Gore,Quebec,Canada
    Default Torque specs for oil filter housing?
    Going to do my spring oil change in the next week or so. This is my first one on the Spyder ( I do them on all my other vehicles/toys) as the dealer did the last one at the 600 mile service. I have a service manual and have located the torque specs for the oil tank/pan plugs, but can't seem to find them for the oil filter and HCM filter housings. I was just wondering if any one would know them or know where they are located in the manual. I see they have specs with the different type of fasteners, is that what people are using? Thanks all for any responses.
    2012 Lava Bronze RT Limited
    Utopia backrest
    Spyderpops Bumpskid
    Diamond R armrest
    Spyderpops belt guard
    Elka stage 1+ shocks
    Seal floorboards
    BajaRon anti-sway bar
    Mar 2008
    Battle Creek, MI
    Both the same...11 Nm (97 lbf-in). The torque specs in the service manual are always shown in the blow-up at the beginning of the appropriate section...Lubrication System and Hydraulic Control Module in this case.
    -Scotty
    2011 Spyder RTS-SM5 (mine) & 2008 Spyder GS-SM5-PE (Nancy's)
    2000 BMW R1100RTP, motorized tricycle & 22 vintage bikes
    Mutant Trikes Forever!
    Mar 2012
    Gore,Quebec,Canada
    Quote Originally Posted by NancysToy View Post
    Thanks, appreciate that Nancytoys! I looked through that section a couple of times, but I will check again! Found it!I was looking in the maintenance section rather then the blow up at the beginning. Thanks again!
    Utopia backrest
    Spyderpops Bumpskid
    Diamond R armrest
    Seal floorboards
    Default Enough said..!!
    There you have it..faster than greased lightning, faster than a speeding bullet, the answer you were looking for...!! we're good..!! that would be Scotty..!!
    ​2012 RS sm5
    Jun 2011
    Near Lexington, NC
    Even tho you're using a torque wrench be sure the setting is accurate so as not to overtighten; too easy to strip out the threads on those filters.
    ted
    Favorite Dealer: Winston-Salem Honda/Can-Am, N.C.
    White 2014 RT SE, Vin 0568 (Sold Aug 16 after purchasing a Slingshot)
    2ndnew tire at 24Kmi..Gen hp43 205-60-15
    New Ignition sys & keys in early '14
    1st Dess Module replaced at 15K
    2ndDess Module replaced at 20K
    Utopia back rest
    Lamonts footpegs
    TricLed brake lights,
    Wired for Gerbing
    Ronbar installed
    Garmin 750 with Ram Mount
    Spyderflaps Mud Flap
    Dimple Drain Plugs
    Tri-Axis handlebar
    Rear brake pads @24K
    Mar 2012
    Gore,Quebec,Canada
    Quote Originally Posted by ulflyer View Post
    My torque wrenches are digital, so should be fairly accurate, but will still be careful after some stories I have heard!
    Utopia backrest
    Spyderpops Bumpskid
    Diamond R armrest
    Seal floorboards
    Mar 2012
    Gore,Quebec,Canada
    Utopia backrest
    Spyderpops Bumpskid
    Diamond R armrest
    Seal floorboards
