looking for part number
2010 RT.... need to replace that rubber gasket around the front fender light. current held together thanks to crazy glue. Anyone know the part number?
Try this....
Go to:
http://www.cheapcycleparts.com/oem-parts/Can-Am/2010
Choose your model and then click on what you are after in the diagram, which will tell you the part number, plus you can order from them. They are quick and reliable; I order few things from them already. Good luck!
Good luck- I couldn,t find it on TWO parts places? I could never find the plastic light cover when I wanted to replace it- It you find it let us know????
Sea Doo GTI-SE 90 Jet Ski!!
Close as I could find???
BRP Parts Catalog Under Electrical Accessories Front
part# 710001478 Position Light Includes 20 to 21
http://www.shspowersports.com/fiche_...mber=710001478 I found this at a Site BUT 40.99 for I guess the cover and rubber gasket?
Originally Posted by SPYDER Mike
Exactly, I thought the same thing , probably the only part on the spyder that does not have it's own part #
Not really...there are a lot of them.
I would consider going to the hobby store, buying some craft foam, and cutting my own gaskey.
